Old 03-17-2011, 10:01 PM   #1
Steve Van Gent
Steve Van Gent's Avatar
will 91 Camero 305 distrib work without ECU
will the 91 Camero 305 stock ECU controlled distributor work without ECU? I see no vacuum advance, so I suspect needs ECU and cam position sensor to work?
Or would I better off continue looking for older HEI smallbock distib? So far, not found one on craigslist...I am building up a 305 with Edelbrock manifold and carb since I dont want to fool with TBI. THis is second one I am building for 72, first one in my 65, works great, cheap, easy to find....
Steve Van Gent is offline   Reply With Quote
Old 03-17-2011, 10:13 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: will 91 Camero 305 distrib work without ECU
Use the older HEI, or just get a "Skip White" Distro off evilbay.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 03-17-2011, 10:21 PM   #3
kaycee
kaycee's Avatar
Look for 1 from the 70's if you can't find 1 I have an extra but shipping would be as much as 1 from the bone yard.Cars, trucks all V-8 will work.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 03-17-2011, 10:25 PM   #4
Warrens69GMC
Did the 305 originally have TBI? You need a "melonized" distribitor for the roller cam.
You might want to swith the roller cam (if equipped) with a Vortec roller cam if out of vehicle.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 03-17-2011, 11:35 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
you need a distributor out of a camAro.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-17-2011, 11:44 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
There are litteraly 100's of thousands of HEI's out there... There are some decent ones in the aftermarket. Which is where I would be looking.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-18-2011, 03:12 AM   #7
C-10 simplex
Gary
Not to mention Crane has a very nice electronic distributor which has recently been reissued Uses infra-red light instead of magnetic pulses for firing signal.
The 91 transmaro distributor does not use cam/crank position sensor and would work w/out ecu but may not run smoothly.
C-10 simplex is offline   Reply With Quote
Old 03-21-2011, 01:19 PM   #8
Warrens69GMC
IF you could wire it to work, you will never be able to drive it. It has no vacuum advance, just a pickup in the dist. You would need something like a msd box to get the stock Distro to work. Better buy a new/used one and be done.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 03-21-2011, 06:21 PM   #9
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
What's a camero? I've never heard of one of those...
-Automatics win races, 6-speeds impress high school kids
-Save a tree, support your local dragstrip.
-"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui
columbuscarsandcoffee.net and on Facebook
ProStreet68SB is offline   Reply With Quote
Old 03-21-2011, 09:11 PM   #10
benoit454
Chris
benoit454's Avatar
it's a special typo edition of a camaro. mr. smarty pants.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Thread Tools
Display Modes
