Old 03-18-2011, 05:36 PM   #1
rumrunnin69
ghost problem with new motor
so i just built a new 350 for my 69 cst dropped it in fired it up and now it wont act right it wont time at all ive re dropped the distributor and its dead on the chain is dead on also ive re adjusted the valves nothing still it runs rough really rough hard to start wont idle unless i turn the idle all the way up and when i throw it into gear it dies instantly!!! im exhausted on every problem im stuck on this one and need an outside perspective my next move is going to be replacing plug wires maybe not enough spark idk if some one has a clue please do tell this is my first engine build by myself but i do have experience.....never seen anything like this
rumrunnin69 is offline   Reply With Quote
Old 03-18-2011, 05:56 PM   #2
Wrenchbender Ret
Re: ghost problem with new motor
Sounds like a bad vacuum leak. Sometimes a guy uses a carb that doesn't match the manifold & it leaves a large opening. Make sure all the tubes in the carb & manifold are used or pluged. I dought if the problem is plug wires.
Wrenchbender Ret is offline   Reply With Quote
Old 03-18-2011, 06:05 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Plus you need to get it diagnosed somehow before you go cranking and cranking on a brand new rebuild. It's a good way to lose a camshaft if its a flat tappet cam.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-18-2011, 06:25 PM   #4
DT1
DT1's Avatar
Did you degree the cam? I'm only asking because I'm one in a million that has actually got a bad grind and my motor was acting somewhat the same. The flats on some of the lobes weren't and the valves were hanging open.
Do a compression check to determine it.
DT1 is offline   Reply With Quote
Old 03-18-2011, 07:06 PM   #5
rumrunnin69
i have not degreed the cam it was used but minimal wear my friend took it out of his camaro cus it was too much for him i replaced the lifters and used it. Its a crane cams energizer with a 440/440 lift pretty beefy but its what i wanted and hey it was free. and i just fixed a stripped screw on the back of the carb that would not tighten like i said it runs just not well idk what else could b done
Old 03-18-2011, 09:14 PM   #6
Hardesty454
Hardesty454's Avatar
Fuel/ air ratio
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 03-18-2011, 09:18 PM   #7
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
intake leak.
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 03-18-2011, 09:22 PM   #8
GASoline71
GASoline71's Avatar
New lifters on an old cam will eat the lifters. Same as if you use old lifters on a new cam, the old lifters will destroy a new cam. Cams and lifters should always go together if they are installed used.
Gary
Old 03-19-2011, 12:09 AM   #9
rumrunnin69
well tomorrow im going to double and tripple check the manifold but i dont hear a vacum leak but i will check and i had the air and fuel ratio at 2 turns i moved it to 2 1/2 turns for the bigger cam i've been messing with the timing cus to b honest i mite have the cam and crank sprocket off a tooth but i want to make sure thats it first before i rip back into that cus it is in the truck. umm if anyone else has a clue please do tell and ill keep u guys posted as well thanx
Thread Tools
Display Modes
