Old 03-20-2003, 09:42 PM   #1
Blue_71
Bloo
Blue_71's Avatar
aaah!! nightmare of a job!
i'll defintly ask more questions before i attack a job next time!! we went to put my 350 and 4 speed in my truck today, cut out the low hump, bolted the engine and tranny together, took it to the truck... no matter what i do i can't slid the tranny in from the front, ive tried jacking up the cab (it's now against the bed) angling the motor backwards, im about to give up and just cut a bigger hole in the cab!!
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 03-20-2003, 09:50 PM   #2
LudwigTheMad
LudwigTheMad's Avatar
if your having that much trouble, jack the whole front of the truck up and then put it......
or you could just put the engine in first, then bolt the tranny to it, but don't cut anymore than you have to.
That's right, I'm back in the game again. No it's not pink.....
1972 Blue and White Suburban.
LudwigTheMad is offline   Reply With Quote
Old 03-20-2003, 09:51 PM   #3
Dads72
We put a 350/350 in the 72 at the same time, but it wasn't much fun.
Can you take the tranny off the engine, install the engine first, and then the tranny?
Might save a lot of grief.
Dads72 is offline   Reply With Quote
Old 03-20-2003, 09:52 PM   #4
Blue_71
Bloo
Blue_71's Avatar
truck IS jacked up, but i was trying to slid everything in from the front (front clip is off) theres just not enough room between the crossmember and the cab for that big bulky SM465 to slid in that way
1989 Chevy K2500
Old 03-20-2003, 09:57 PM   #5
rustyold69
student wrench turner
rustyold69's Avatar
you might want to try taking the transmission crossmember off. It should give you more than enough room to slide it in.
1969 Chevy C-10 with 250 L6
2002 GMC Sierra 2500 HD Duramax with banks six gun
rustyold69 is offline   Reply With Quote
Old 03-20-2003, 10:32 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
remove the cover on the tranny that the shift forks attach to. Better get instructions first as it's a b_tch if you don't follow the right procedures
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-20-2003, 10:35 PM   #7
Blue_71
Bloo
Blue_71's Avatar
where could i find the instructions at? i never even thought about that
1989 Chevy K2500
Old 03-21-2003, 10:30 AM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
I beleive chassis overhaul manual? The trick is to set the shift forks in proper position before removing cover. Possibly reverse?
I'd definately find some confirmation before proceeding. This is what we did to get the 402BB/4 speed combo into my son's truck a couple years ago as we had same problem.
Old 03-21-2003, 11:05 AM   #9
nightmare
nightmare's Avatar
you might want to try this too. install the tranny first, but don't bolt it in, push it as far back as possible, then get the engine in. should be the easiest way. just a suggestion
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 03-21-2003, 01:08 PM   #10
still w.i.p '68
Dreams are free
still w.i.p '68's Avatar
I put the big block, with turbo 400 attatched in my truck with the clip off, and the tranny cross member out (I was changing it from standard to auto cross member) with out alot of cussing, although next time I might attatch the motor mnts to the motor, instead of the frame/cross member.. ( also I used late model mnts) this may or may not make it any easier...Good luck, and remember when you get pissed, and through tools, you just have to go pick them up.LOL
'68 swb fleetside
originally w.i.p '68
member since 1-01
w.i.p = ( work in progress )
still w.i.p '68 is offline   Reply With Quote
Old 03-21-2003, 01:58 PM   #11
71jwalker
Take out the crossmember, and after setting it down on the motor mounts jack up the transmission and put the cross member back in. I have done this in several cars and trucks with the front clip still on.
71jwalker is offline   Reply With Quote
Thread Tools
Display Modes
