Old 03-24-2011, 10:41 AM   #1
matthorvat
c notch strength
after installing a notch, properlly, is the section behind the notch as strong and supported as it was before hand?
im building a custom trailer for myself. i have designed a air ride suspension, but it would require a notched frame for the best result as far as lowering it. making loading and unloading a breeze for those frame scrapers!
help guys, ideas, thoughts, suggestions?
matthorvat is offline   Reply With Quote
Old 03-24-2011, 12:02 PM   #2
stich626
Re: c notch strength
I think if towing it be an issue
but c notch on the trailor to drop it.. the bed load is spread out
stich626 is offline   Reply With Quote
Old 03-24-2011, 01:09 PM   #3
kile_hays
put your air bags directly over the rearend...i have found in my recent experience that if your towing a load or hauling heavy things that airbags does great over the rearend then compaired to on the link bars
kile_hays is offline   Reply With Quote
Old 03-24-2011, 01:55 PM   #4
SCOTI
SCOTI's Avatar
C-notching the frame weakens the frame unless you maintain the original height of the frame above the notched area.The overall strength is in the height of the frame rail.
Boxing the inside of the rail or plating the outside will help restore some strength but it will not return it to what it was originally rated. Good reading here....
http://67-72chevytrucks.com/vboard/s...d.php?t=393867
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Thread Tools
Display Modes
