03-24-2011, 07:45 PM | #1 |
What's that sound?.....
I've had a squealing sound coming from the engine/transmission for about a month now, i have replaced the following: Harmonic balancer, water pump, ac pulley, alternator pulley, and throwout bearing and re- aligned clutch and pressure plate.
Heres where it gets tricky... It makes a loud squeaking sound when the clutch is pressed in, or after it has been when your driving it. I made some calls today and was told that it could be the thrust bearings in the engine? Engine is off a fresh rebuild...havent even met the 500 mile mark yet..any help appericated.
70 Chevy C10, LT1, T5, "Blue Beast" |
03-24-2011, 08:05 PM | #2 |
Re: What's that sound?.....
If your thrust bearing goes out you should see brass/bronze/copper looking metal pieces in you oil.
Could also be your input shaft bearing to the tranny or the throw out bearing. Does it act funny when you drive it or does it just make a noise. |
03-24-2011, 08:10 PM | #3 |
fly wheel?
71 GMC 1500 LWB Last edited by Spoof; 03-24-2011 at 08:10 PM. |
03-24-2011, 08:12 PM | #4 |
Belts?.............
03-24-2011, 08:16 PM | #5 |
No it dosent shift or drive any different, its just a loud squeal or squeak. The thing that was pointed out to me, is that the harmonic balancer moves slightly when the clutch is pressed in, hence where everyone said thrust bearings. also I should mention that the squeal does not happen when parked in neutral, only with the clutch engaged. New fly wheel, got it when we rebuilt the engine. The serpentine belt is new, so im pretty sure its not slipping.
03-24-2011, 08:18 PM | #6 | |
Also would the thrust bearing going out cause it to squeal like a freakin pig?
03-24-2011, 08:24 PM | #7 |
Do these things have pilot bearings/bushings?? Might be that.
03-24-2011, 08:25 PM | #8 |
Newbee
Cut the oil filter apart, and look for copper chunks in the filter pleats. That is the easiest/cheapest way to check for bearing dammage. A moving damper on a fresh motor is not a good sign.
03-24-2011, 08:26 PM | #9 |
Yeah, when i pulled the transmission to replace the throwout bearing it was fine.
03-24-2011, 08:27 PM | #10 |
Does it do it only when driving or also sitting. I ask because mine squeals sometimes when driving but I know it's the speedometer cable making the noise.
03-24-2011, 08:28 PM | #11 |
Newbee
03-24-2011, 08:28 PM | #12 |
it does it at both times AS long as the clutch is pressed in.
03-24-2011, 08:29 PM | #13 |
ok. Makes sense, im going to change the oil tomorrow...i hope its not that...less than 500 miles and ill have to go through it again...lol.
03-24-2011, 08:50 PM | #14 |
Currently Blazerless
Does it only do this after the motor has warmed up?
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
03-24-2011, 09:16 PM | #15 |
if you can see the balancer move when hitting the clutch you got bigger problems
03-24-2011, 11:07 PM | #16 |
Active Member
This is what my brother and I did to find a rattle on his vehicle many years ago but if you do it it's at your own risk. (Gotta say this these days...)
We chocked the front wheels, raised the rear wheels and put them on jack stands. Started the engine and I got under the car and watched and listened with my "stethoscope" -a 2 foot piece of gardent hose while my brother worked the clutch and shifted the gears. With the garden hose to my ear I could listen at various locations to get an idea where the sound was coming from. IIRC, in our case it turned out to be a rattle inside the tranny. |
03-25-2011, 06:06 PM | #17 |
My guess the squeeling is coming from your wallet!!
I really don't know. I'm not a very good mechanic but I sure am a good parts changer!! Good luck! Keith |
03-30-2011, 11:42 AM | #18 |
Newbee
The suspense is killing me...
Any updates? |
03-30-2011, 01:09 PM | #19 |
throwout bearing. i had this hapen in an old truck i had
03-30-2011, 01:19 PM | #20 |
Me too, wonder what it is?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
03-30-2011, 01:29 PM | #21 |
Rusty Nuts
I know this is going to sound crazy, but i had a loud squealing noise on a fresh rebuild and it was driving me crazy. It took me a couple of hours to figure it out. And what it was i had all my breather holes on the valve covers blocked and the squealing noise was comming from the dipstick tube. and when i pulled the dipstick out it went away. Bottom line engine was creating to much vacum in the block.I put a breather cap on and never heard it again. This might be your case. but it happens
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 Last edited by Mr Chevorlet; 03-30-2011 at 01:30 PM. |
03-30-2011, 02:40 PM | #22 | |
Active Member
A friend once complained that his transmission was going out on his old datsun with floor shift. It was making a whirring sound when he shifted to second gear. I drove with him for a block or two and found out the boot was torn and when he shifted up it opened it up. He was hearing road noise. Saved him from buying a transmission. |
03-30-2011, 02:50 PM | #23 |
I agree, thats where I would look first
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
03-30-2011, 03:34 PM | #24 |
He said he has already replaced the throwout bearing....
03-30-2011, 06:46 PM | #25 | |
Thread Tools | |
Display Modes | |
