Old 04-01-2011, 01:09 AM   #1
jd hauler
1972 gmc tach wire
does anyone know which wire runs the tach? I have an unhooked yellow wire out under the hood, with a spade connector, but want to make sure, and does anyone know how the backlighting for the tach works? I dont see any bulbs with the twist in socket for the tach? thanks In advance.
jd hauler is offline   Reply With Quote
Old 04-01-2011, 01:35 AM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: 1972 gmc tach wire
Looks like you need a boost to the top.....ttt!
ETsC10 is offline   Reply With Quote
Old 04-01-2011, 07:48 AM   #3
JimKshortstep4x4
The existing bulbs on either side of the tach provides light for it. Factory tach wires are not yellow. I suspect that it could be for an emissions system. Where is the wire located?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-01-2011, 08:51 AM   #4
70cst
70cst's Avatar
Here you go jd hauler ... a bump to the top.
By the way and from Ohio...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-01-2011, 08:58 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
The original tach wires are Red & Brown. Red to power (ignition unfused on the fuse panel) and Brown to negative side of coil or "TACH" terminal on distributor.
LockDoc
Leon
Old 04-01-2011, 11:00 AM   #6
jd hauler
ok, thanks , one more wire question, I have a heavy black wire that comes out of my steering column with a soldered on brass terminal, the truck had cruise , as it still has the button, now I have a diesel motor in it. would this have been the wire for that, or did the shift indicator have backlighting? any chance this cruise could still be used for the 6.2 diesel?
Old 04-02-2011, 11:43 AM   #7
jd hauler
the yellow wire is to the left of the air cleaner looking at the motor, up in the wire tray, any idea what that is for?
Old 04-02-2011, 02:35 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the black wire in the column isn't a wire, but a fiberoptic cable that lights the shift indicator. It's supposed to plug into one of the twist in bulb holders on the inst panel.
The yellow wire on the passneger side of the motor probably goes down to the starter. I suspect your truck has been updated with an HEI system and no longer needs that yellow wire. If this is the case, you can cut it out.
Old 04-02-2011, 08:09 PM   #9
jd hauler
I gotcha, I was wondering how that worked because of no ground wire and didnt see any type of bulb in the indicator, and yes I now have a 6.2 diesel living in the old truck, thanks for your help. any chance of getting the fiber cable to work? I dont know if I ever will, do you know where its suppose to plug in, or could it be fed from any light?
Old 04-02-2011, 10:47 PM   #10
05crewcab
05crewcab's Avatar
Welcome!
You are going to have to figure out a different way to run the tach, or perhaps you can't run it at all with the diesel. There is no distributor, coil, HEI, etc. to hook a wire up to.
I have no idea how to run a factory tach with a 6.2, but I am sure someone will chime in.
The fiber optic cable uses a special bulb connector in the instrument panel. it is white, and the rest are black. if I recall, it is on the left side by the speedometer.
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 04-03-2011, 11:15 AM   #11
jd hauler
I saw some tach converters on ebay, one guy told me to tap my center diode and run a wire outside the alternator and then to the converter and then to the tach, at least I found the red and brown tach wires, I did see that white bulb holder and had no idea at the time what that was for, not sure I want to dismantle the dash again, might just run my own wire and light bulb.
Thread Tools
Display Modes
