Old 04-01-2011, 06:52 PM   #1
Garthc20
Garthc20's Avatar
a couple of newb questions
1 how do I replace the badge on my hood , I have a new one do I need to buy new fasteners?
2 I just installed a parking brake cable , how much tension should it have and should I tighten it when on or off?
3 the PO.s kid put a bunch of spongebob stickers on the glove box lid whats the best way to get them off without ruining the paint
4 I have an electric fuel pump should it have a filter before it or after?
1970 Custom camper 20 lwb
1978 yamaha xs1100
(insert clever quote here)
Garthc20 is offline   Reply With Quote
Old 04-01-2011, 08:08 PM   #2
70cst
70cst's Avatar
Re: a couple of newb questions
A bump for you...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-01-2011, 08:12 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Goo-Gone is what I use.
Here is another remover being discussed: http://67-72chevytrucks.com/vboard/s...41#post4591041
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-01-2011, 08:18 PM   #4
70cst
70cst's Avatar
Thanks for the info...
Old 04-01-2011, 08:25 PM   #5
Garthc20
Garthc20's Avatar
very interesting, Im going to see if I can get them off with a hot soapy towel, if not I will try something a little more strong. any ideas on the other stuff?
1978 yamaha xs1100
Old 04-01-2011, 08:38 PM   #6
674x4ton
When i was working in a body shop we use a hair dryer to heat the stickers then slowly peel them off.
674x4ton is offline   Reply With Quote
Old 04-01-2011, 08:40 PM   #7
70cst
70cst's Avatar
Good point...I forot about that method.
Old 04-01-2011, 09:49 PM   #8
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
I'll take this one...4) I have an electric fuel pump should it have a filter before it or after?
both, I know the sending unit in the tank has a "sock" but I would still run a pre pump filter, put it right where the fuel line goes out the floor of the cab. there is a section of rubber hose there. Then put a second filter near the carb. If you are running a factory quadrajet you need to discard the original filter inside the fuel inlet of the carb.
good luck
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 04-01-2011, 11:54 PM   #9
Garthc20
Garthc20's Avatar
the reason I ask about the filter is that it seems to be starving the pump and making quite a racket , also it is mounted to the cab which might be part of the extra noise , but the filter is right over the exhaust pipe and I have a feeling the gas is getting boiled out of the filter, can you show me a pic of how it should be mounted?
1978 yamaha xs1100
Old 04-02-2011, 09:56 AM   #10
gcburdic
Restoration Virgin!
gcburdic's Avatar
I think you can access the badge fasteners from the inside of the hood...remove and slide the old one out new one in
I've read to set you ebrake tension, push your ebrake pedal down half way, hook everything up....
I'm going from memory here, so I'm sure others will chime in if I'm off my rocker with either of these
Good luck and to the truck boards from NC
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-02-2011, 10:18 AM   #11
Garthc20
Garthc20's Avatar
Can I. Re use the nuts for the badge
1978 yamaha xs1100
Old 04-02-2011, 11:06 AM   #12
gcburdic
Restoration Virgin!
gcburdic's Avatar
I don't see why not...unless they are damaged
Geoff with a G
Old 04-02-2011, 12:13 PM   #13
Garthc20
Garthc20's Avatar
I was wondering about that because the posts aren't threaded
1978 yamaha xs1100
Old 04-02-2011, 12:16 PM   #14
Sinister
Between Trucks...
Sinister's Avatar
You can reuse the nuts for the badge. Remove the hood latch pin from the hood, remove old badge, install new one.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-02-2011, 02:07 PM   #15
Garthc20
Garthc20's Avatar
well got a couple of things done thanks for the info
heres the old one
and the new one
I didnt have to pull the latch, there was enough clearance with the one hole in the hood and also the hole where the latch hook goes
1978 yamaha xs1100
Old 04-02-2011, 09:26 PM   #16
chevytruckluver
Sorry I dont have any pics, but if the fuel filter is close to the exhaust pipe I would move it! I would tuck the filter inside the frame rail and use a clamp to keep it tight against it. (no rattle) this will also keep the exhaust heat away from the filter.
Trey
72 Short Step
Thread Tools
Display Modes
