Old 04-02-2011, 09:26 PM   #1
Tagar89
I'ma yearnin for some learnin!
Tagar89's Avatar
Rusted cab and misc part swap
So I have a 68 Chevy seaside with rust everywhere, cab, genders, etc. So I went to the junk yard and found a beautiful 72 gmc. I was wondering if any of them are swappable mainly the cab and core support.
If there not what's so different about them?
Thomas
1968 Chevy C10 Shortbed Stepside
Tagar89 is offline   Reply With Quote
Old 04-02-2011, 09:30 PM   #2
hugger6933
Re: Rusted cab and misc part swap
most of that stuff is interchangable. Jim
hugger6933 is offline   Reply With Quote
Old 04-02-2011, 09:31 PM   #3
Jeffs70
Jeffs70's Avatar
i know the cab is swappable but not sure about the core support. but im sure someone else will chime in that knows
Jeffs70 is offline   Reply With Quote
Old 04-02-2011, 09:32 PM   #4
Tagar89
Tagar89's Avatar
Edited
Old 04-02-2011, 09:33 PM   #5
Tagar89
Tagar89's Avatar
What's different between the cabs if anything.
This truck also has disc brake, would they be swappable also.
size=1]Posted via Mobile Device[/size]
Old 04-02-2011, 10:19 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The cabs are swappable.The differences are the E-Brake setup.Get the cables and they can be converted.There is a screw under the vent window to hold the door together better by the window.The mirror mounts differently.
That's all I can remember right now.
The core support has different light bucket set-ups but IIRC they can be changed.I'm not sure about the shape of the core support and you may need different mounts.
The disc brakes are a straight swap.Just unbolt the whole front crossmember and swap it in.Get the MC Booster and Prop valve from the 72 also.The plumbing will also make the swap easier.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-02-2011, 10:56 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
Core support is different because it'll have four lights and the mount area is different from 69-up also.
Cab would interchange pretty much 100%.
If you get the disc brakes, you'd need the rear off the 72 also or conversion axles for the rear of the 68 because the 72 would be 5 lug...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-02-2011, 11:22 PM   #8
Tagar89
Tagar89's Avatar
Fenders?
I notice in the pictures I took that it was a 3/4 ton so there 8 lug disc. Bummer.
Thanks everyone for your help
Old 04-04-2011, 06:41 PM   #9
Tagar89
Tagar89's Avatar
Will 68' doors fit on the 72 cab?
Thread Tools
Display Modes
