Old 04-03-2011, 02:41 PM   #1
4matty3
4matty3's Avatar
truck wont start help
at the sellers house it started up fine, with the help of a jump. as soon as i got it home to start it up, it wouldnt. So then i put my jumper cables on it and then the wires started to smoke and bubble up( the ones on the battery). now nothing happens when i turn the key.any ideas what i can check or look for??
also i thought black was negitive???
also heres the one of the wires that bubbled. i replaced one that was terrible but it didnt do anytihng
anybody have any idea?? i dont know where to start
1971 c10
4matty3 is offline   Reply With Quote
Old 04-03-2011, 02:47 PM   #2
QKENUF4U
QKENUF4U's Avatar
Re: truck wont start help
positive goes to starter
negative goes to ground
not sure what the small red wire is for (resistor ?)
looks like you got jumper cables backwards to me...
check all fuses...
QKENUF4U is offline   Reply With Quote
Old 04-03-2011, 03:27 PM   #3
4matty3
4matty3's Avatar
ya i had it backwards. (what an idiot). think i did any damages? thanks
1971 c10
Old 04-03-2011, 03:45 PM   #4
don t. - 72gmc
It all depends how much and from where you let the smoke out(grin).
Since it did run, air and gas should not be an issue.
Get a good/better battery, clean up the connections and follow the spark or more like where there is no spark. Look for more "bubbled" wires, tape as you go for now.
HTH..good luck...don t. ....
don t. - 72gmc is offline   Reply With Quote
Old 04-03-2011, 04:05 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
You can't go by wire color on used trucks this old. Lots of "creative" wiring is usually from PO's. Always see where the pos and neg is on the battery.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-03-2011, 04:31 PM   #6
Rooster's 67
Rooster's 67's Avatar
you will most likely need a new alternator and if it has an HEI the module will probably need replacement also. neither of these components will generally survive reverse polarity application. and any wiring that shows bubbles in the insulation needs to be replaced.
and check all fuses.
Rooster's 67 is offline   Reply With Quote
Old 04-03-2011, 04:34 PM   #7
GASoline71
GASoline71's Avatar
Also check your voltage regulator.
Gary
Old 04-03-2011, 05:12 PM   #8
lil hoodlum
lil hoodlum's Avatar
OOPPSS! I hope you get it all figured out!!
Good luck!
Keith
lil hoodlum is offline   Reply With Quote
Old 04-03-2011, 06:57 PM   #9
4matty3
4matty3's Avatar
I did get it figured out! finally it starts up, just replaced the bubbled wires and hooked it up to a battery charger. now all it needs are some brakes. then i can somewhat drive it/move it around.
heres a video of it running and how bad of shape its in, hopefully by the end of summer it will be somewhat decent.
1971 c10
Old 04-03-2011, 07:11 PM   #10
Luvlegs
Luvlegs's Avatar
I was thinking - that's not so bad - but, the bed IS bad - but it did remind me of how much I miss the sound of my old truck (20 years ago).... been running around with a 6 for a few years now...sigh... A little soap, a little sandpaper and touch up, toss a blanket over the seat, some plywood in the bed (minus the extra steel), get it road safe and drive the bejeepers out of it.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 04-03-2011, 07:48 PM   #11
4matty3
4matty3's Avatar
thats what im planning for. a little hard work and hopefully ill have a decent truck
1971 c10
Old 04-03-2011, 09:56 PM   #12
stsalvage
Scrapper 1
stsalvage's Avatar
the battery cables I'm not one for those cable attacher's I like the Lead one that are all one battery cables.There better ground You might want to go down and buy some sea foam its will help you engine and your oil and make it idle better And if you have miles on that engine Best off to Use a Can of ( Restore ) it comes in a chrome can here is a picture
stsalvage is offline   Reply With Quote
Thread Tools
Display Modes
