Old 04-04-2011, 11:07 PM   #1
badriand
badriand's Avatar
bed panel bolts rubbing cab
Anyone else have the issue where the top front bed panel bolts rub the cab occasionally? Mine seems to rub i assume when i hit a big dip or something. I thought about drilling top bolt and putting a carriage or something, any other ideas don't really want to do that?
badriand is offline   Reply With Quote
Old 04-04-2011, 11:17 PM   #2
TopFuel1966
TopFuel1966's Avatar
Re: bed panel bolts rubbing cab
It sounds like you don't have a sufficiently wide enough gap between the cab and the bed. It should be about 1/2 inch at the beltline. Someone may have removed and replaced the bed and didn't adjust the gap properly.
TopFuel1966 is offline   Reply With Quote
Old 04-05-2011, 12:00 AM   #3
badriand
badriand's Avatar
i put the bed back on a couple of weeks ago and i have the cross-sills pulled back toward the rear as far as they will go. Measuring i have about quarter of an inch between the end of the hex bolt and the cab. From the bed panel to the cab i have a little over 1/2 inch.
Old 04-05-2011, 03:17 AM   #4
TopFuel1966
Is this a Fleetside or Stepside bed you have? The 1/2 inch gap at the beltline on my Fleetside bed leaves about 3/4 inch between the boltheads and the back of the cab. Don't know about a Stepside but a 1/4 inch at the boltheads on either one doesn't sound like enough to handle any flexibility. You may need to hog out the frame holes a little to allow you to move the bed back a bit more. I had to do that with mine to get the correct fit from side to side.
Old 04-05-2011, 07:44 AM   #5
badriand
badriand's Avatar
Fleet side. When i say rub I guess I should say it barley knicked the paint. Thx , guess I will have to do some adjustments.
Old 04-05-2011, 09:17 AM   #6
LeftCoast32
Custom Builder
LeftCoast32's Avatar
If you have a 3/4 ton Chassis you may have bad rear cab mounts that will let the back of the cab hang and sag.
LeftCoast32 is offline   Reply With Quote
Thread Tools
Display Modes
