Old 04-05-2011, 10:51 AM   #1
bddcustoms
bddcustoms's Avatar
Question Cleaning a Rusty Master Cylinder Brake Fluid Resevoir
Hey Board,
How do I clean this out?
Thx
DTT
Let's Go Os!!!
broke d!@k dog Garage
1969 C20 - Project: "Big Sexy" [http://67-72chevytrucks.com/vboard/s...d.php?t=454894]
2003 'Burban - [Big Pop's daily driver]
1969 350/350 Stingray - [as soon as the economy turns...]
1939 Chevy Roadster Pick Up - Project: "Pre-School" (searching now)
bddcustoms is offline   Reply With Quote
Old 04-05-2011, 10:58 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Cleaning a Rusty Master Cylinder Brake Fluid Resevoir
Looks like it's had some water in it for a while, and if the reservoir is that rusty, the cylinder bore probably is too. I'd replace it for no more than they cost and save yourself a headache later.
ls1nova71 is offline   Reply With Quote
Old 04-05-2011, 11:15 AM   #3
Beat68CST
Beat68CST's Avatar
I'd try puttin some CLR in it and lettin it sit for a few.
Beat68CST is offline   Reply With Quote
Old 04-05-2011, 11:32 AM   #4
LEEVON
Moderator
LEEVON's Avatar
CLR or wood bleach powder/water. Soak it for awhile, should be good.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 04-05-2011, 12:20 PM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I'd get a rebuilt, they're about $15
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-05-2011, 12:28 PM   #6
stich626
this is your brakes,, either take it apart and clean it and add new seals after a light hone, or replace it.. being cheap here is stupid.. a good rebuild is 70 bucks.
cheap ones are 18-20.
a rebuild kit to do yours is 20-25..
stich626 is offline   Reply With Quote
Old 04-05-2011, 01:47 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Yours seems to have quite a bit of rust and it could be pitted internally. Back in the old days we used to rebuild them by honing, new seals, pistons, etc. These days, it's not worth the effort. If you're patient and do a good job it can be done but otherwise as some mentioned above buy one. You can get high dollar ones but I've used the Napa ones and other local parts places and they've held up pretty well.
Be aware that even new ones can be defective so be sure and do a careful job of bench bleeding following the instructions carefully. Before taking it on the road do some testing in the drive way then around the block and or an empty parking lot if possible.
68gmsee is offline   Reply With Quote
Old 04-05-2011, 02:08 PM   #8
cdowns
cdowns's Avatar
if you like the truck stopping when you want it to stop a new master is cheap compared to brake failure when your life depends on it
Old 04-05-2011, 02:26 PM   #9
stich626
I will be rebuilding mine, as it has bleaders on it..
it's easy to do..
Thread Tools
Display Modes
