Old 04-09-2011, 09:04 PM   #1
jessewebb
jessewebb's Avatar
My 69 C/10 project
Hi all, I've been doing a few odds and ends to my truck, I use it every day to work out of unless I have some spare time to replace some of the rusting parts. I bought some inner fenders and a radiator support during the winter and since the weather is warming up, I thought I'd replace them. I also changed out the wiring harness to the front end. I took some before and after pictures and wanted to share them. Everything I've used so far is used. It takes some time to shine them back up, but I'm saving some money and I'm satisfied with the results.. Here's what I've accomplished so far..
Pete
The worst I ever had was wonderful
69 SWB work in progress
97 Ranger 6in. lift on 35's
04 325i lady's ride
jessewebb is offline   Reply With Quote
Old 04-09-2011, 09:08 PM   #2
jessewebb
jessewebb's Avatar
Re: My 69 C/10 project
Been getting things took apart and ready to refinish the used parts to put back on my daily driver..
Pete
04 325i lady's ride
Old 04-09-2011, 09:14 PM   #3
jessewebb
jessewebb's Avatar
I'm readt to paint the inner fenders and radiator support, Took a wire brush on my drill and a sanding mouse and smoothed everything up. Put some rust proof paint on first then a coat of regular paint to get the shine and added some undercoating on the inner fenders Rust Olium Brand...
Pete
04 325i lady's ride
Old 04-09-2011, 09:35 PM   #4
jessewebb
jessewebb's Avatar
I'm putting my truck back together now. I have the wiring harness replaced, Have the radiator and support back in. Installed new support bushings. I read a thread about how to refinish my grill. I'm also in the process of doing that. I'll post more pics as I get them.. Thanks for looking, Any Advice will be appreaciated...
Pete
04 325i lady's ride
Old 04-10-2011, 12:08 PM   #5
RCbowtie69
RCbowtie69's Avatar
Nice!!!!!
RCbowtie69 is offline   Reply With Quote
Old 04-10-2011, 01:53 PM   #6
jessewebb
jessewebb's Avatar
Thanks for the vote of confidence, I got the inner fenders mounted along with the radiator and support, new support bushings, new bolts and clips for the fenders. I had a pretty rough time with the bolts under the inner fenders. They had broken off. So I drilled them out and rethreaded them. Put about twice the bolts in than I took out. I'm hoping that will take some rattle out of it. Thats about it for today. The weather here is awesome today. Need to spend some time with my other baby, don't want her to feel like she's being left out.
Pete
04 325i lady's ride
Old 04-11-2011, 09:09 PM   #7
jessewebb
jessewebb's Avatar
Got a little more accomplished today. Install the swaybar I purchased from KrazyRay, Bought the bushings from Brothers. Moved my tranny cooler from the grill to the radiator support used brackets and clamps instead of plastic ties. Going to post a couple pics of my progress to keep up with.
Pete
04 325i lady's ride
Old 04-11-2011, 09:54 PM   #8
robzilla
robzilla's Avatar
do you have a link to the grill refinishing?
thanks
robzilla is offline   Reply With Quote
Old 04-12-2011, 06:27 AM   #9
jessewebb
jessewebb's Avatar
heres a thread......http://67-72chevytrucks.com/vboard/s...estoring+grill
I read this thread and done some research, It takes some time, the results are defiantly worth it. I'll be posting some before and after pics of my grill when I get it finished.
Pete
04 325i lady's ride
Old 04-12-2011, 05:34 PM   #10
Steve-W
Steve-W's Avatar
Nice truck and good progress it'll be a while before mine will look anything like yours how much did the sway bar set you back?
Steve-W is offline   Reply With Quote
Old 04-12-2011, 05:50 PM   #11
jessewebb
jessewebb's Avatar
I have about $80 in the whole thing. KrazyRay had a few for sale on here and I bought one from him. I've been working on my grill today, going to post a few pics, shortly
Pete
04 325i lady's ride
Old 04-12-2011, 06:17 PM   #12
jessewebb
jessewebb's Avatar
Got another day to work on my grill, After I took it off. I sprayed it down with paint stripper (aersol type), let it sit for a few minutes to get the paint off and it help remove any grease and bugs. After wiping the stripper off I sprayed it down with oven cleaner (easy off) let that sit for around an hour, took a water hose and hosed it off. I let it dry by on its own. That removed all the oxidation. I started with 400 grit sand paper and started sanding by hand. Sanded about 3 hours on and off the first day. Decided I needed to do something else. I took a black/decker sanding mouse with 320 grit and pretty much knocked it out in an hour. Still had to use the 400 grit to smooth out the swirls, also took a small brass bristle brush to get into the knooks.. still went over that with the 400 grit. After getting the grill smoothed up I hosed it down again then took 1000 grit sand paper and wet sanded the entire grill again. Thats it for now, I'm going to polish and shine it up tomorrow and put it back on the truck, hope to post pics of the finished product then...All total I have about 4 hours of actual work into it.... First two pics are before and last to are after sanding. Oxidation had been removed.
Pete
04 325i lady's ride
Old 04-13-2011, 03:05 AM   #13
dmack91
dmack91's Avatar
Looks good! Aren't you going to need to clear coat it with something to prevent it from oxidizing?
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 04-13-2011, 06:07 AM   #14
jessewebb
jessewebb's Avatar
Yes, I' going to use a clearcoat spray after I buff and shine it up. It can also be oxidized, but I have no idea how that works. I've read in other threads that clearcoating it will work, may not last as long. But that's the route I'm taking. Thanks for the question.
Pete
04 325i lady's ride
Old 04-14-2011, 09:07 PM   #15
jessewebb
jessewebb's Avatar
Polished my grill today, starting to shine now. Used Mothers aluminum cleaner and a buffer. Have the black painted back on it. Put new letters on it. Sprayed it down with clearcoat Dupont brand. I'm satisfied with the results. It's not show quality, by far. It didn't cost much, just a little time...
Pete
04 325i lady's ride
Old 04-15-2011, 03:39 PM   #16
jessewebb
jessewebb's Avatar
Finished up my project, Got my truck back together, play time is over. Back to work on Monday.. Turned out good for an amateur. In my yard garage. Thanks for all the feedback
Pete
04 325i lady's ride
Old 04-15-2011, 03:52 PM   #17
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Grill turned out very nice..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-15-2011, 05:58 PM   #18
Steve-W
Steve-W's Avatar
for an amateur?...you're a pro!
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Old 04-15-2011, 06:53 PM   #19
robzilla
robzilla's Avatar
sorry for asking so many questions, but where did you get the letters? i don't remember seeing them in any books i have.
Old 04-15-2011, 07:10 PM   #20
jessewebb
jessewebb's Avatar
I got those awhile back. I think I got them on ebay. Actually forgot about having them. I'll check and see if I can find when I bought them.
Pete
04 325i lady's ride
Old 04-15-2011, 08:47 PM   #21
jessewebb
jessewebb's Avatar
Thanks to everyone for the great remarks. It took some elbow grease, But I enjoyed every minute of it, especially the feedback.. Thanks
Pete
04 325i lady's ride
Thread Tools
Display Modes
