Old 04-19-2011, 05:11 PM   #1
jjtackleberry
jjtackleberry's Avatar
stock Oil gauge question
I'm trying to do a cluster swap....
The mechanical gauge kit I got at the parts store, isn't working...
it wont thread on, but looking at the picture you can see its a different thread.
any ideas??
'71 Chevy LWB all OG
'86 Chevy LWB all OG
It's all a matter of perception
jjtackleberry is offline   Reply With Quote
Old 04-19-2011, 07:09 PM   #2
swamp rat
swamp rat's Avatar
Re: stock Oil gauge question
Yea the cluster thread is most likely an American thread and the brass fitting is metric.
You will probably have to find an American brass Ferrel fitting that will fit the gauge, then remove the one on the plastic line and replace it with the new one. Also if you can find it there are replacement copper lines that are a bit better than the plastic.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-19-2011, 07:09 PM   #3
jjtackleberry
am i embarassing myself...or ???
Old 04-19-2011, 08:29 PM   #4
Dark Knight
Dark Knight's Avatar
I had the same dilemma. I just went to Ace Hardware and picked up a compression fitting that had male threads on both ends. It has to fit the threads inside the gauge, not the ones on the outside. Worked like a charm.
http://www.plumbingsupply.com/images...sion-union.jpg
Something like this. Just remove the nut from one side, thread it into the gauge, and put the line into the other side.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Thread Tools
Display Modes
