Old 04-19-2011, 09:14 PM   #1
'65 chevy lover
Hello...have questions about '65 chevy pickup
Hello everyone. My name is Spanky. Just aquired a '65 chevy pickup, long/wide bed. Truck already has ( I believe...numbers on motor are 3970010 ) a late 70's/early 80's 350 with turbo 350 trans. I need several things. 1st: I want to add power steering. What power steering pump and steering box would be the best to use? 2nd: I need the eye bolts that hold the emergency brake cables...I believe there should be three of them. 3rd: I need the u shaped brackets that connect the e-brake cables from the rear drums to the other cable and all other brackets to connect all this together. Will post pics of truck ASAP.
Thanks,
Spanky
'65 chevy lover is offline   Reply With Quote
Old 04-19-2011, 09:50 PM   #2
DPowers
DPowers's Avatar
Re: Hello...have questions about '65 chevy pickup
Welcome to the site. Theree is a FAQ section at the top that has a whole passle of info.
Here is a link to the PS switch
http://67-72chevytrucks.com/vboard/s...d.php?t=438509
Here is another good site.
http://www.persh.org/pickup/IdeaPage.htm
Good luck and keep us posted.
DPowers is offline   Reply With Quote
Old 04-19-2011, 10:35 PM   #3
Red65C10
Red65C10's Avatar
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=89
Billy
65 C10
............................... ____
................ ________-|___\____
.;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________
P.S. Send truck money !
Red65C10 is offline   Reply With Quote
Old 04-20-2011, 12:30 AM   #4
Captainfab
60-66 Nut
You will need a power stering box from any '69-'87 2wd pickup, Suburban or Blazer. As for the pump and brackets, you will need those based on what water pump is on your engine. There is a short water pump and a long water pump. The short pumps were used thru '72 on the trucks, and '68 for passenger cars. Another thing to consider is that after about 1980, the hose fittings changed to a metric size with an O-ring. So it would be best to get a box and a pump with the same style of fittings. The pump brackets can be changed to the correct style if need be. Let me know if you want to get a steering box adapter plate.
Old 04-20-2011, 08:32 AM   #5
lakeroadster
Originally Posted by Red65C10 View Post
LMC doesn't sell the u-bolt pieces. FYI: Be sure to price compare before using LMC, they really gouge you on some of their parts....
You might PM jonzcustomshop for those. He has a lot of original pieces parts.
Or try Rich Sisneros in Colorado, his email is rjsisneros@ria.net
Other Parts Vendors you could check with:
http://www.ClassicParts.com/
http://www.thetruckshop.com/
http://www.bowtiebits.com/
http://www.americanclassic.com/
http://www.jimcartertruckparts.com/
http://www.earlyclassic.com/
http://www.golden-state-parts.com/
http://www.fillingstation.com/
http://www.ecklerstrucks.com/
lakeroadster is offline   Reply With Quote
Old 04-20-2011, 10:57 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Welcome to the forum '65 chevy lover.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-20-2011, 07:05 PM   #7
'65 chevy lover
Thanks for the welcome and the info.
Old 04-20-2011, 07:15 PM   #8
'65 chevy lover
Thanks for the info. Already checked LMC for the brake stuff. They have the cables but not the eye bolts or, the u-shaped brackets.
Old 04-20-2011, 07:25 PM   #9
'65 chevy lover
Thanks for the info. I was assuming ( yeah, I know what assuming will get you...LOL ) the steering box would just bolt on to the frame. Why is the adapter necessary? Is it an alinement issue? Also, how do I know if the water pump is long or short...is it total width or, distance from front of the block?
Old 04-20-2011, 07:28 PM   #10
'65 chevy lover
Thanks for the info and links. Already been on most of those web sites but, will check the others and e-mail jonzcustomshop and Rich Sisneros.
Old 04-20-2011, 07:48 PM   #11
'65 chevy lover
Old 04-20-2011, 08:42 PM   #12
DPowers
DPowers's Avatar
SWP from the surface that mounts to the block to the nose is 5 5/8"
LWP is 7"
SWP Pic
Old 04-20-2011, 08:50 PM   #13
badblu97
Double 6's
badblu97's Avatar
[QUOTE=Why is the adapter necessary? Is it an alinement issue? Also, how do I know if the water pump is long or short...is it total width or, distance from front of the block?[/QUOTE]
The adapter plate makes it so you can bolt the steering box right to the frame, no problems. Get the one from captainfab, its great quality and works like he says it does. If you havent checked his signature, do that, it explains a lot. You also have to shorten the steering shaft, and use some of the steering tie rods and such. Its best to get the whole steering assembly from a donor square body. He also makes a bracket to put an 88-98(i think) Chevy truck booster on your firewall. Also good stuff. Just put both on my truck.
As far as the long or short water pump, as far I know, a short water pump is right up against the timing chain cover, and the long has about enough space to put your hand in between the pump and timing chain cover (approximately)
and, Welcome to the Forum, you will find tons of great people, and tons of great info! And WE LOVE PICS!!!
Street Glidin!
1966 LWB Custom Cab (sold)
1982 Short Fleet (under the knife)
1998 S10 2wd Fleet
2007 Chevy Silverado Crew
2007 Harley Davidson Street Glide
badblu97 is offline   Reply With Quote
Old 04-21-2011, 11:09 AM   #14
kieth
kieth's Avatar
Youcan also use the whole front crossmember and disc brake set up from a 88-91 suburban.........
kieth is offline   Reply With Quote
Old 04-21-2011, 06:21 PM   #15
'65 chevy lover
Thanks for the info!
Old 04-21-2011, 06:22 PM   #16
'65 chevy lover
Thanks for that info!
Old 04-21-2011, 06:44 PM   #17
Woogeroo
I've bought parts from RJ/ Rich Sisneros myself, a good guy to deal with.
-W
some ebrake information
Woogeroo is offline   Reply With Quote
Old 04-25-2011, 07:09 PM   #18
'65 chevy lover
Finally got some pics of my truck. Got it up on jack stands because I'm rebuilding the front brakes. Going with new rotors and calipers. The old calipers got stuck and thoroughly trashed the rotors. While I'm at it, I'm gona replace ball joints, tie rods etc.
Old 04-25-2011, 07:12 PM   #19
'65 chevy lover
A couple more pics...plz don't laugh to hard at the fuel tank in the bed...I got it that way...LOL Person that had it before me put it there to have more room for speakers
Thread Tools
Display Modes
