Old 04-20-2011, 11:47 PM   #1
Mog
Mog's Avatar
Needs some ideas to make my 70 more street friendly
Need suggestions to lower my RPMs when I'm at highway speeds. I have a TH350 that is in its highest gear at around 25mph. Love another gear but don't have the funds for a new tranny right now. Changing gear ratios? That's not much cheaper right? What about changing shift points?
70 Blazer K5
Mog is offline   Reply With Quote
Old 04-20-2011, 11:57 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Needs some ideas to make my 70 more street friendly
What gears are you running and what size tires?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-21-2011, 12:10 AM   #3
Mog
Mog's Avatar
4.11 gears with LT245/75R16 tires. Getting 33's in the near future though.
70 Blazer K5
Old 04-21-2011, 05:13 PM   #4
IGOR
IGOR's Avatar
Overdrive tranny will give you best bang for your buck. Lots of people (or at least two I know of: AJ, VT) have had good luck with the 700R4 / NP208 combo. I would start looking around for a used setup or try and rob one out of a cheap parts K5 of newer vintage.
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer
1972 K10 - Rust Bucket, TBD
1976 C10 SWB, 350 / T350
My blazer build thread:
https://ck5.com/forums/builds/72-k5-...17-update.410/
IGOR is offline   Reply With Quote
Old 04-23-2011, 07:53 PM   #5
Mike C
Mike C's Avatar
Wow. Highway ain't much fun, huh? 4.11 and an auto would like 35" or 37" tires. Will make the biggest difference, especially if you are going to have to get tires anyhow. But 33's is about all that will fit without 4" lift.
No cheap way out of this one. 35's and a lift will cost $1500 plus wheels if you need them. TH700R4 conversion will cost at least $2000 to use your 205 case, and gears and swap will run you $1000. At least.
Get the tires first, you will be surprised at the difference it makes. I went to 28" tall tires on my Camaro from 26" and it was quite noticeable.
You might find someone to swap you front and rear axles, but that most likely will get you 3.73. Which is only a 10% reduction, but combined with a set of 33's would at least make it realistically driveable.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-23-2011, 08:17 PM   #6
71Rat
ran out of money
71Rat's Avatar
find a set of axles is probly your cheapest bet to swap. can normally find 1/2 tons for cheap or free when people swap to 3/4 or 1 tons
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 04-23-2011, 09:36 PM   #7
Mog
Mog's Avatar
Guess I'll see where I'm at (with funds too) once I get the 33's. Not sure I want to go much bigger, won't be able to fit in the garage! Want to give it a wider stance, which I think will require wider rims. I figure I could sell the TH350 to help offset the cost of a 700R4. The 350 is less than a year old, Jasper. Gotta be a market for those, right? Thanks for all the suggestions.
70 Blazer K5
Old 04-23-2011, 10:19 PM   #8
1972CST
1972CST's Avatar
You could twist my arm and I might trade your 4.10 axles for my 3.07 axles... that would get your RPM,s down
1972CST is offline   Reply With Quote
Old 04-23-2011, 11:32 PM   #9
72lb4x4
With a K5, a trans and TC are probably easier than diffs or diff gears front and rear.
72lb4x4 is offline   Reply With Quote
Thread Tools
Display Modes
