Old 04-21-2011, 06:22 PM   #1
trapperjack
trapperjack's Avatar
Thoughts and ideas needed......
A buddy has my old 62 K10, and needs front axle. We found a matched set from a 90 Blazer, 10 bolt 3.42"s with springs. Good swap? The price is right.
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
Old 04-22-2011, 01:04 AM   #2
Captainfab
60-66 Nut
Re: Thoughts and ideas needed......
It depends on what the '62 is being used for. The 10 bolts are good for most uses, but if he is beating on them with big tires mounted to them, they may not last long. Also the 3.42 gears may or may not be what he needs , there again depending on the size of tires, and the transmission in use. Basically need a little more info.
Old 04-22-2011, 09:17 AM   #3
trapperjack
It's not going to be a trail rig or jacked up. He's going to use it to beat around in, short trips to town, and on his place. It's got the 235 and 420 transmission. Has new 10.50x15 mud terrains on it. Nothing fancy.
Thanks.
Old 04-23-2011, 12:32 AM   #4
Captainfab
60-66 Nut
Those should be a good set of axles for that application then.
Old 04-23-2011, 11:46 PM   #5
trapperjack
Thanks. I think he's picking them up Monday.
Thread Tools
Display Modes
