anybody running a muncie 4 speed with the stock bench seat in a task force truck ? if so what shifter are you using ? i have a hurst comp plus but the shifter arm looks like its going to be way short ( came out of a camaro)
fan of "Butters" Stotch
Re: muncie 4 speed + stock seat?
Here is a thread with some newer trucks, if it helps any
http://67-72chevytrucks.com/vboard/s...d.php?t=379993
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again ![]() |
Yes it is to short just ex-stand it
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project) It's your ride build it the way you want !!!!!!!!!! ![]() |
I don't have a task force truck but will offer this up, for whatever it is worth.
Hurst makes a shifter specifically for a 4-speed Muncie in a truck, basically just a longer handle. http://www.summitracing.com/parts/HUU-3917308/ For my '65 C10 I bought their shifter for a '57 Chevy, it moves the shifter forward to help clear the seat. http://www.summitracing.com/parts/HU...n/?prefilter=1 I ended up using bucket seats and a blazer console though. ![]() Last edited by lakeroadster; 04-22-2011 at 10:40 AM. |
I have that same setup in my 57, but I did it 32 years ago. Don't remember what I did. The knob is close to the seat but does work. I did put an extension on the shifter to make it taller, actually its a old rod and piston out of a Briggs and Stratton. The throughs are very long, the linkage needs to be modified so the throughs sre not so long.
Steve |
we used to have the seat notched and that gave you the clearance you needed for the shifter.
Thread Tools | |
Display Modes | |
