hard to steer?
I know with no ps the steering is tough,, but my truck is a bear.. it has 215 radials on the front and the steering has about 1/8 of a turn of slop.. but this thing is hard on the arms,, any adjustments that I can make to loosen it up?
55 second series with 235,, and factory steering wheel.. thanks TC |
Re: hard to steer?
Have you done any thing to the front end new tie rods or ?? mine is all original and it's not to bad.I think your tires might hurt you a little allso I'm running 235/75/15.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Re: hard to steer?
Tire size is what is killing you. these were originally designed to skinny tires at high pressure. In the 60's a 6.50 was considered wide (6.5") most ran 5.50's. My first 4wd conversion used the stock box and it got destroyed with only 7" wide tires. Adding ps to 2wd is relatively easy, lots of threads here on how to do it.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 04-22-2011 at 02:23 PM. |
Re: hard to steer?
thanks guys,, it needs new tie rods for sure, bounces around after each bump,,
looks like I'm going to spend some money,,urgh!!! TC |
Thread Tools | |
Display Modes | |
