posi rear end kit
Anybody heard of a kit to convert a stock 65 chevy SWB rear end into a posi rear end? If so wear can I get one and how difficult is it to do it?
[B][I]1965 Chevy C10 SWB w/350(68-79), 305 H.O Heads, Edelbrock Performer 1406 600 cfm carb, Torquer II Manifold, AC Delco HEI, TH400, Flowmasters,3.07 gears 2005 GMC Yukon XL Denali w/Mangnaflow Exhaust 1983 Cutlass Supreme w/ 350, cam, Holley 650 cfm, Street Dominator intake, carb spacer, hydromatic, Flowmasters Patriots always talk of dying for their country but never of killing for their country. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: posi rear end kit
There is no special kit needed to install a posi into a '65 or newer truck 12 bolt. The '63 & '64's require changing the side spider gears. All you need is a posi unit for a truck 12 bolt. The truck 12 bolts were used from '63-'82. You may also need an installation kit, which will have new bearings and seals. The typical posi unit will require a professional to install correctly, unless you posess the necessary skills and tools to do so. An exception to that is the lock-Rite unit that will fit into your existing carrier. There are a number of sources for either of those such as , Summit Racing, Jegs, Randy's Ring and Pinion, Reider Racing, Drivetrain Specialties, Drivetrain Wharehouse, etc.
Does 2.34 gears sound rite for a 65 swb with stock gears?
60-66 Nut
Nope. The most common stock gear in these C10 trucks is 3.73's. 4.10's were an available option.
my truck has a real high gear in it also,,i need to switch to 3.73...but dont want to purchase wrong parts
Thread Tools | |
Display Modes | |
