Old 04-28-2011, 10:28 PM   #1
tim21391
tim21391's Avatar
massive problem
truck only starts if u sit there and crank and crank and crank.. then it will sputter and shoot gas outta the carb.. so i then rebuilt carb.. then it sputters more so i restabbed distributor so then now it wont even start after i shut it off.... had it running once after i restabbed distributor.... so what do i do next? plugs?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-28-2011, 11:36 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: massive problem
you sure the distributor was at correct tdc? And what timing are you running? Also, have you verified the plug placement is correct?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-29-2011, 01:03 AM   #3
dmack91
dmack91's Avatar
Re: massive problem
Sounds like something is seriously messed up with your timing. Any chance the timing chain skipped a tooth?
Was it running ok before/how long ago?
If it is a points distributor, I lost condenser once and it caused it to backfire to the point I destroyed my exhaust system. The flashes coming out from under the hood were impressive too.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 04-29-2011, 01:05 AM   #4
dmack91
dmack91's Avatar
Re: massive problem
double tap
Old 04-29-2011, 01:06 AM   #5
SSchevimp
Re: massive problem
points or hei?
70 c10 long bed
57 chevy 2 door wagon
07 tahoe
96 civic commuter
SSchevimp is offline   Reply With Quote
Old 04-29-2011, 01:15 AM   #6
Blazenherbs
Blazenherbs's Avatar
Re: massive problem
Sounds like your timing is of or your wire’s are wrong double check your firing order and reset your distributor where there is compression on the Number one cylinder…Hope this will help you..
Blazenherbs is offline   Reply With Quote
Old 04-29-2011, 05:18 AM   #7
cdowns
cdowns's Avatar
Re: massive problem
makin sure of TDC un compression stroke s a must when installing dizzy
points gap or dwell MUST be set after cleaning checking points in dizzy
Thread Tools
Display Modes
