Old 05-01-2011, 07:58 AM   #1
thebeast61
thebeast61's Avatar
alternator brackets?
I am converting my 61 GMC with the 305 to an alternator. Does anyone know which brackets to get for this. I can find lots of different brackets but just not sure which ones work for my motor. I am going with the 12 SI delco if that matters.
I am trying to get the wiring harness from Mad electrical but he is hard to get a hold of and he dosent have online ordering.
Is there anything else that I will need?
Oh and what belt will i need or will the old one work?
Thank you
thebeast61 is offline   Reply With Quote
Old 05-01-2011, 12:04 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: alternator brackets?
I am not sure about the belt or wiring but I know those alternator brackets are rather difficult to find. You can ask on Jolly's site if anyone is selling them there.
Old 05-01-2011, 12:46 PM   #3
Wrenchbender Ret
There is a universal mounting kit available. You can usually modify the gen. brackets to work.
Wrenchbender Ret is offline   Reply With Quote
Old 05-01-2011, 02:30 PM   #4
jocko
jocko's Avatar
Some options:
If you're keeping the stock exhaust with the generator adjustment mounting tabs on it, here's an option (these are somewhat "universal" so might be what you need with the ol GMC: http://www.alternatorparts.com/Alter...brackets_1.htm
Here's a whole slew of options, but you've probably already seen these online:
http://www.google.com/search?q=alter...w=1892&bih=871
I've found that the adjustment arm is readily found at about any swap meet, but then again, I've been spoiled by Carlisle and Pomona...
Having said all that - sorry, but i'm not familiar with how the curved adjusting arm would/should mount to a GMC motor - may be able to improvise with one of these things though. Even chev had horizontally and vertically mounted bolts for adjusting arms, so something should work.
Old 05-03-2011, 11:17 PM   #5
thebeast61
thebeast61's Avatar
ok thanks for the info. i will give the universal a try.
Old 01-28-2012, 06:04 PM   #6
Andyboy
Andyboy's Avatar
Had to bring this thread back to the top. Can someone post pics of the generator and alternator brackets. Is there a big difference between the two? I'm looking to go with an alternator.
Andyboy is offline   Reply With Quote
Thread Tools
Display Modes
