Old 05-01-2011, 09:37 AM   #1
67Step
67Step's Avatar
Question About Brakes
When I apply the brakes on my 85 chevy truck the driver's side rear tire locks up. If push on the brakes easy the tire will not lock up. What do you think is causing this? Thanks in advance.
1967 Chevy Shortbed, 454 CI, 700R4, currently work in progress. Check out the build up at http://www.cardomain.com/ride/2933497/1.
http://67-72chevytrucks.com/vboard/s...d.php?t=264458
1956 Chevy 3100 4x4 Stepside Truck. Sitting on Tahoe frame with LS motor.
67Step is offline   Reply With Quote
Old 05-01-2011, 10:06 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Question About Brakes
Check that wheel for signs of fluid leaks. Its possible you have a leaky wheel cylinder.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-01-2011, 11:11 AM   #3
mooseknuckles
mooseknuckles's Avatar
mine does the same thing! seems to do it more in the mornings tho... I'll have a look at it soon, as I'll be ripping them off for good!
mooseknuckles is offline   Reply With Quote
Old 05-02-2011, 02:32 PM   #4
Rons86
Rons86's Avatar
Had a friends truck doing the same thing a few years ago (except the passengers side was locking up.) Turned out the drivers side parking brake cable was frozen up and not letting the drivers side brake work properly. Just something to check on.
Rons86 is offline   Reply With Quote
Old 05-04-2011, 07:41 PM   #5
1425956
1425956's Avatar
I just recent;y fixed the same problem I was having with my truck. There rear drums would lock up once the pedal was pushed to a certain point, or if I pressed the brakes very quickly. Turns out both my wheel cylinders were leaking and the brake hardware was rusted pretty bad. I turned my drums, new brake shoes, new wheel cylinders and an all-in-one kit to replace rusted springs, etc... Brakes work perfectly now. Hope this helps.
Jeremy
I have done so much, for so long, with so little, I can do anything with nothing!
1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.)
1986 GMC Suburban 3/4 ton 4x4
2014 GMC Sierra LTZ Z-71 Crew SWB
1425956 is offline   Reply With Quote
Old 05-04-2011, 09:21 PM   #6
67Step
67Step's Avatar
Thanks. Hopefully I get to tear into it tomorrow and see what the problem is. Thanks for your comments. I will post after I check it out and find the problem. It is just the drivers side back tire doing it. But of course will check them both.
Old 05-04-2011, 09:22 PM   #7
Eyegore
What Hump?
Eyegore's Avatar
You might try bleeding the system first, those little bubbles do strange things, same thing happened to my 86, bled the system and everything was fine.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 05-06-2011, 07:54 AM   #8
67Step
67Step's Avatar
N2Trux you hit the nail on the head. Pulled the hub off the truck and found that the wheel cylinder was leaking and had covered everything. Brake shoes were coming apart and real sticky. Took the passenger side apart and found the other side was also leaking but not as bad. Changed it all out. Went to put new wheels and tires on the truck and found I needed front brakes also. So the old truck got new brakes all the way around. Brakes working good now. Thanks for all your info and comment. Just another reason to be a member of this GREAT site.
Old 05-06-2011, 08:14 AM   #9
67Step
67Step's Avatar
Trying to post a picture here.
Old 05-07-2011, 04:34 PM   #10
67Step
67Step's Avatar
I guess it worked. I see it. LOL!!
Thread Tools
Display Modes
