Old 05-05-2011, 04:36 PM   #1
blackbeaSSt
2002 burb bad o2 sensor
had the check engine light come on so i ran it to my mechanic and checked the codes. bad o2 sensor in bank 1 sensor 1. he said it could run anywhere around the $150 range for the sensor. does that seem about right?
blackbeaSSt is offline   Reply With Quote
Old 05-05-2011, 05:00 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 2002 burb bad o2 sensor
Rockauto has the Original delphi's for $40 or others for as low as $23.....get the Delphi's
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-06-2011, 11:18 AM   #3
blackbeaSSt
thanks usm! sometimes i think since my mechanic is a one man show he has to up the price of things to make up for lost time on other cars
Old 05-09-2011, 09:06 AM   #4
blackbeaSSt
ok so i called around to some places and they said bank 1 sensor 1 is considered upstream. im looking at all these places online and there are like 10 different ones to choose from. some i take it are just the sensor (spark plug looking things). and some have what look to be a harness with it, and then some come with a harness looking thing and a bunch of extra goodies.
which one do i need? and any reason why i shouldn't go ahead and replace both sensors?
oh and the local places quoted around $89 or upstream sensor and around $109 for downstream
Old 05-09-2011, 11:12 AM   #5
usmcchevy
usmcchevy's Avatar
Yes sensor 1 is up stream. I would replace both of the up stream sensors and you want the "direct replacement" sensors. The ones that come with all the other stuff are universal sensors and expect you to cut and splice the new sensor in. I'm not a fan of Universal or parts store brand sensors, just too much trouble when you can get the original equipment Delphi's online for cheap.
Build thread
LSx Swap FAQ index
Old 05-09-2011, 01:47 PM   #6
blackbeaSSt
ok im in no way a mechanic so pardon my ignorance, but how many sensors are on these things? the guy that i called said there was just 1 up and 1 downstream
Old 05-09-2011, 05:03 PM   #7
usmcchevy
usmcchevy's Avatar
No problem. 4-one up stream(before cat) on each side of the engine and one down stream (after cat) on each side. The rear (after cat) are just there to make sure the cats are doing their job. The front (before cat) provide data to the computer so it can do its job.
Build thread
LSx Swap FAQ index
Old 05-09-2011, 09:22 PM   #8
blackbeaSSt
ugh. yeah not that i know theres 4 i think i'll stick to replacing just the one for the time being
thanks usm
Old 05-10-2011, 09:12 AM   #9
blackbeaSSt
yeah i think im gonna have to break down and buy one locally. my wife took it out this morning and after getting gas it started sputtering something awful and the check engine light started blinking
so i called napa and they have a bosch in stock for $61.99. but they said they can sell it to the mechanic doing the work for $54. i thought cool that'll work. so i call up the shop near my work, who does a good job on cars, and they said that they charge $83.40 and hour for labor and the parts would run $120ish. i quickly chimed in saying that i called napa and the part would be $54. he said that they then have to cover the mark up which is nearly $70
funk that. i'd rather pay the kid across the street who is taking auto classes at the local junior college to do it then pay those thieves!
Old 05-10-2011, 08:09 PM   #10
blackbeaSSt
well, i sucked it up and ventured out to do it myself. got the part at lunch and the socket after work. well come to find out that i bought the USA version of the sensor when in fact i needed the canada one (go figure right!). so my luck napa closed at 6 so i ran to oreilly and picked up one for $54. with my limited knowledge of cars i must say that this was very simple.....after i found the wd40 to loosen it up
so i spent roughly $65 when the local mechanics wanted parts and labor were a minimum of $200. sheesh! im gonna teach my 2 daughters who to work on cars so they don't get screwed when they are older!
Thread Tools
Display Modes
