Old 05-06-2011, 01:29 PM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
airbags question
I'm working on my trucks rear airbags. I've been planning on moving them. And having them sit on the 4link. Question is does it matter were the sit on the link. Closer or further from the axel.
Sick5 is offline   Reply With Quote
Old 05-06-2011, 01:31 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: airbags question
I have done this twice. On my 65, they were half way up the trailing arms. On my 61 they are just a few inches forward of the original coil spring loction. I thought both worked well for me.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 05-06-2011, 01:37 PM   #3
61_FL_Apache
Who Me?
my 65
my 61
Steve
2001 Blazer 4D 2WD
Old 05-06-2011, 01:39 PM   #4
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Mine would be a few inches further up. Just wondering how it rides. And it came down about 3 inches lower
Old 05-06-2011, 01:48 PM   #5
61_FL_Apache
Who Me?
The bags have about 45psi in each and it rides like a caddy.
Steve
2001 Blazer 4D 2WD
Old 05-06-2011, 02:39 PM   #6
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
What kind of bags are they.
Old 05-06-2011, 02:43 PM   #7
61_FL_Apache
Who Me?
I don't know the brand and they are not marked. They are 7" and 2500-2600# range.
Steve
2001 Blazer 4D 2WD
Old 05-06-2011, 03:24 PM   #8
Slow Build
Slow Build's Avatar
I would think the closer you have the springs to the rear axle would put less stress on the bushings and the trailing arms. If you are going to carry any loads I would keep them close to the axle.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 05-06-2011, 03:33 PM   #9
61_FL_Apache
Who Me?
I would agree!! I never hauled anything in my 65 so it didnt matter. There is more of a chance to haul some gear in my 61.
The ride is good!!
Steve
2001 Blazer 4D 2WD
Old 05-06-2011, 03:51 PM   #10
7T2
Active Member
7T2's Avatar
If I remeber correctly, further away from the axle gives you more travel and faster lifting, closer to the axle gives you more weight carrying capacity.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 05-06-2011, 04:41 PM   #11
61_FL_Apache
Who Me?
True.
The further away give you more leverage to squeeze the bag for a nice ride. I was worried about a stiff ride with them close, but that wasnt an issue either.
Steve
2001 Blazer 4D 2WD
Old 05-06-2011, 09:18 PM   #12
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
here are some pic of what im working with passenger side is done just need to trim it. driver side im working on tomorrow
Old 05-06-2011, 11:31 PM   #13
creep
Registered Loser
creep's Avatar
If I were you I'd use bigger bars if you're going to mount your bags to them, to prevent them from bending. I believe ***************** makes gussets you can weld to the bottom of your bars to give them some extra support.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 05-07-2011, 12:30 AM   #14
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Dude for sure, that is gonna bend ....
Just make up something like this:
My paint skills suck, but you get the idear !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 05-07-2011, 01:03 AM   #15
Slow Build
Slow Build's Avatar
x2. Those bars are made more for a for/aft stress. I don't think they're really meant as load bearing tube in that way. If you put the airbags that far towards the front of those thin bars (if I'm seeing it right) I see catastrophic failure in your future. I may be wrong, but I don't think so.
Past GM Trucks:
Old 05-07-2011, 09:00 AM   #16
lakeroadster
In regards to the location of the air spring consider the trailing arm / 4-link bar as a lever arm.
The rear curb weight for a '65 1/2 ton pickup is about 1800 lbs. That means you will need 900 lbs of force to lift one rear wheel off the ground if the air spring is located at the rear axle.
Now lets say your trailing arm length is about 48 inches and you want to put the air spring in the center at 24 inches.
48 inches x 900 Lbs = 43,200 in-lbs
43,200 in-lbs / 24 inches = 1800 lbs
So each air spring will need to lift 1800 lbs to lift the truck. And the related suspension components will also need to handle that much force, just to lift the rear of the truck up off the bump stops. That's without any payload.
It becomes pretty obvious, pretty quick, why the air spring needs to be as close to the axle as possible in order to reduce the size of the components required to handle the loads.
I wouldn't put the air spring on the 4-link simply because it wasn't designed for that. Compare your 4 link bar to a stock trailing arm. The 4 link bar needs more section height for the application you are considering. Even if you gusset the bar as ChiefRocka discussed above are the rod ends adequate to handle the side loading that results due to the air spring?
lakeroadster is offline   Reply With Quote
Old 05-07-2011, 10:24 AM   #17
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Well I'm glad I ask the question before continuing this project. Over the middle axel didn't really give me a lower stands and much of a side to side. I'm going to grind it of and place off of the cnotch. Back to.the original plan.
Old 05-07-2011, 10:32 AM   #18
lakeroadster
Old 05-07-2011, 01:10 PM   #19
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
here sre a few pic of the over the side axel top plate. im not to happy about it because too close to the rim
Old 05-07-2011, 01:32 PM   #20
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Avs has a behind axel lower plate for 22 a piece. And top for the same price. Anyone bought this before?
Old 05-08-2011, 07:50 PM   #21
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
would this work?
Thread Tools
Display Modes
