Old 05-08-2011, 11:59 AM   #1
TomBennett
TomBennett's Avatar
Carb Help!
Having starting problems with my Edelbrock Carb. I can't get it to start after it sits without dumping gas down in the primaries. I notice when I push the accelerator no gas comes out into the primaries. Once it starts it idles fine and if it will rev if I am slow and smooth with the accelerator. If I punch it quick it will bog down. Any help quys?
TomBennett is offline   Reply With Quote
Old 05-08-2011, 12:24 PM   #2
Wrenchbender Ret
Re: Carb Help!
You obviously have a bad accelerater pump. Make sure the linkage is hooked up. If so you will need to take the top off the carb & check the pump plunger.
Wrenchbender Ret is offline   Reply With Quote
Old 05-08-2011, 12:29 PM   #3
TomBennett
TomBennett's Avatar
Re: Carb Help!
what should i be looking for?
Old 05-08-2011, 01:52 PM   #4
Daddy Brim
Daddy Brim's Avatar
Re: Carb Help!
Lots of good info here http://www.edelbrock.com/automotive_...ech_vids.shtml
Daddy Brim is offline   Reply With Quote
Old 05-08-2011, 02:02 PM   #5
70cst
70cst's Avatar
Re: Carb Help!
Originally Posted by Daddy Brim View Post
Very good info Daddy Brim ....
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-08-2011, 08:02 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Carb Help!
You can buy a acc pump for like $10 I think thru summit etc
John
1999 Toyota Tacoma 4x4
Old 05-08-2011, 08:48 PM   #7
BIGKEV
Re: Carb Help!
Your local NAPA should have them also. I've found that NAPA tends to be a little cheaper than summit/jegs on eddy parts, at least the one here is.
BIGKEV is offline   Reply With Quote
Thread Tools
Display Modes
