Old 05-08-2011, 03:09 PM   #1
jjtackleberry
jjtackleberry's Avatar
Cluster lights problem
I did the cluster swap....but the cluster lights don't work.
Turn signals work...high beam indicator works...but no other lights...
Any ideas...the bulbs are good...
'71 Chevy LWB all OG
'86 Chevy LWB all OG
It's all a matter of perception
jjtackleberry is offline   Reply With Quote
Old 05-08-2011, 04:56 PM   #2
DesertCat
DesertCat's Avatar
Re: Cluster lights problem
First thought... make sure your dash lamp dimmer isn't turned down (turning the headlight switch).
Second, check the connection where your dash connector is, could be a bent or missing contact on the circuit board. Make sure you are getting voltage up to that point.
You changed the whole cluster or just the bezel?
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 05-08-2011, 05:51 PM   #3
jjtackleberry
The whole cluster...went from 3 gauge to the 7 gauge cluster....
Everything works....well except for the gauge lights...
I'll check those things
Old 05-09-2011, 12:44 AM   #4
MistaGavin
MistaGavin's Avatar
If you know you're getting voltage for the instrument lights, try cleaning the bulb contacts on the printed circuit sheet. Perhaps trace the copper strips to see if it is broken with a ohm meter. You might need a new printed circuit, which are fairly inexpensive.
You're not old, it IS loud!
1970 CST-10 BB 400
MistaGavin is offline   Reply With Quote
Old 05-09-2011, 02:27 PM   #5
sameyrasmea72
sameyrasmea72's Avatar
If you go from a 3 guage cluster to a full cluster isn't there something you have to do to the harness?
Also, there is a fuse that works those lights as well as the taillights.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 05-09-2011, 03:32 PM   #6
DesertCat
DesertCat's Avatar
I don't think that is so... also checked the schematics, looks separate to me.
Just sayin'....
Old 05-09-2011, 05:53 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
There is definitely a difference between the plug in harness as to how they are wired. The first diagram is how the 3 gauge cluster is wired and the second is how the gauge cluster should be wired. There is also a fuse for both types and it is labeled Pnl lights in the fuse panel. The gray wire is the hot wire for the panel lights. The gauge cluster must be grounded well also.
Name:  idiot light connector diagram.jpg
The cluster lights are wired at 12 on the idiot light cluster and at 8 on the gauge cluster. The fuel gauge goes from 7 to 3 and the temp gauge goes from 5 to 6.
Name:  cluster connector with gauges.jpg
You can also see the ammeter wires go to 1 and 12 on the gauge cluster.
The oil pressure and generator lights go away and the turn signal lights flip flop.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-09-2011, 07:20 PM   #8
sameyrasmea72
Just sayin'....
I have a short somewhere in mine and it blows the fuse about once a week, so I am pretty sure.......Just sayin'
72 Cheyenne Super
Old 05-09-2011, 10:07 PM   #9
t&tkennels
t&tkennels's Avatar
had a similar problem with mine, try running a ground wire from the back of the gauge panel to a good ground.
t&tkennels is offline   Reply With Quote
Thread Tools
Display Modes
