Old 05-08-2011, 07:22 PM   #1
ubtripn
ubtripn's Avatar
PS conversion saga-journey into insanity part 2-help pls
Well, I got the brackets working, the new pump fits perfectly in them and the whole unit into the truck BUT the pulley sticks out to far to align with any of my grooves on my harmonic balancer. Please see the pics below. I have two questions:
1. Does my truck have a short or long water pump and does it matter?
2. Do power steering pumps come with different size pulley shafts because when I put the pump in the brackets I am only 1 grooves length away but it sticks out too far to hook to anything? and I have 3 grooves down below but they are obscured in the pic by a belt laying across them,
I am losing my mind on this one. I need some last advice from this generous group.
I used the brackets from the van and just chopped of the piece that would have attached to the exhaust because my alternator already does so, have a look.
What are my options here?
Name:  2011-05-08 16.27.26.jpg
Name:  2011-05-08 16.27.53.jpg
Name:  2011-05-08 17.04.44.jpg
Name:  2011-05-08 17.04.56.jpg
ubtripn is offline   Reply With Quote
Old 05-08-2011, 07:28 PM   #2
mightymouse
mightymouse's Avatar
Re: PS conversion saga-journey into insanity part 2-help pls
i dont know but in the pic looks like maybe pulley on p/s pump turned around backwards?
mightymouse is offline   Reply With Quote
Old 05-08-2011, 07:31 PM   #3
ubtripn
ubtripn's Avatar
Wow, I gonna go check right now, thanks for the input.
Old 05-08-2011, 07:33 PM   #4
ubtripn
ubtripn's Avatar
I think that was it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!thanks!!!!!!!
Old 05-08-2011, 07:33 PM   #5
67Slider
67Slider's Avatar
^^Looks that way to me too.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 05-08-2011, 07:34 PM   #6
Autoblueprint
Autoblueprint's Avatar
It is on backwards.
You MAY need a special tool to PRESS the pulley on...do NOT hammer the pulley on.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 05-08-2011, 10:39 PM   #7
ubtripn
ubtripn's Avatar
Well, got it in the truck and it is off center a little. Enough for the pulley to slightly rub the second bracket which by the way I cannot figure out the purpose it serves. (As everybody can tell by now I am learning and humbled) But I am thinking about just using the rear bracket with the two bolts going to the block and the two bolt to the ps pump one of which is adjustable. The bracket that goes on top is buying me no extra support from what I can tell. Anybody ever just use a flat bracket with the four holes one of which is elongated for adjusting?
Old 05-08-2011, 11:45 PM   #8
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
I use both. The cast front bracket keeps the pump square under belt tension & load so the belt doesn't pop off.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 05-09-2011, 08:10 AM   #9
ubtripn
ubtripn's Avatar
So I see more grinding in my future. Also, the shaft on my new pump moves in and out if you push and ppull just a little (1/16 to 1/8 of an inch) is this normal?
Old 05-09-2011, 08:38 AM   #10
taank
Yes.
taank is offline   Reply With Quote
Old 05-09-2011, 09:18 AM   #11
Husker
Husker's Avatar
Moroso I think makes a shim kit if you need to shim so your pulleys line up.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 05-09-2011, 09:20 AM   #12
Richard H.
Spanked once
Richard H.'s Avatar
You have a short pump and I think the ps pulley is for a long pump with ac.
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 05-09-2011, 02:17 PM   #13
ubtripn
ubtripn's Avatar
I see, I was just going to shim with washers since it not too far off. However, I have 3 grooves on the pulley on my harmonic balancer down below, can I just use one of those?
Old 05-09-2011, 03:20 PM   #14
taank
I see, I was just going to shim with washers since it ot too far off. However, I have 3 grooves on the pulley on my harmonic balancer down below, can I just use one of those?
Go to junkyard. Get entire serpentine belt setup from a 96 silverado. Bolt on. And be done with it. No more bull**** adjustments. And no squeaky belts!
Old 05-09-2011, 03:34 PM   #15
ubtripn
ubtripn's Avatar
I want to have separate belts for my alternator, ps and eventually ac, that way when one goes I don't lose everything until I get a new belt. But thanks for tha advice. I did consider that option earlier.
Old 05-09-2011, 09:27 PM   #16
Richard H.
Spanked once
Richard H.'s Avatar
On the crank pulley ... closest to the engine is the alt. middle is ac outside ps. with a short pump.
Oh, if you have a short pump crank pulley.
Old 05-09-2011, 11:30 PM   #17
Autoblueprint
Photo shows a long water pump.
John Harlowe
Old 05-10-2011, 08:19 AM   #18
ubtripn
ubtripn's Avatar
That is great information thank you! I got the pump in, have a look, I think if I put the right pulley on it will work. It would work now but the alt belt misses the inside groove of the pulley on the oump by 1/4 inch. Could I just get a pulley with the outside groove and not 2 grooves. Do I in fact have the wrong pulley? Check out the pics: Plus the cracnk pulley slants slightly upwards towards the hood with the engine and my pump does not. I don't know if it is enough of a difference to matter though?
Name:  2011-05-08 17.24.52.jpg
Name:  2011-05-09 18.42.15.jpg
Name:  2011-05-09 18.42.37.jpg
Name:  2011-05-09 18.42.54.jpg
Old 05-10-2011, 09:08 AM   #19
ubtripn
ubtripn's Avatar
So I can run a belt straight to the crank thuogh and be ok right?
Old 05-10-2011, 09:22 AM   #20
ubtripn
ubtripn's Avatar
I have the alternator on the wrong crank groove, that solves that. Thanks richard h.
Thread Tools
Display Modes
