Old 05-08-2011, 10:29 PM   #1
Joemomma1
Joemomma1's Avatar
To those who added factory boosters
I picked up a unit and have everything minus the 3 bolts with the phillips head. What did you use? Looks like it needs to mount flush in the wedge piece.
Also, I currently have a 72 3/4 ton booster on and am wondering what kind of a difference will I notice going to the stock setup?
Thanks.
Joemomma1 is offline   Reply With Quote
Old 05-09-2011, 12:29 AM   #2
Captainfab
60-66 Nut
Re: To those who added factory boosters
The '72 C20 booster should be a dual diaphram booster. Not knowing just what you are changing to, you may see a decrease in braking power (harder pedal)
Old 05-10-2011, 05:13 AM   #3
Woogeroo
Whoever set up the layout on my 1965 c10 chevy used the 9 inch 1965 power brake booster and the 1969 gmc(that was how it came up in the NAPA parts system when I had to replace it) dual pot master cylinder going to front and rear drum brakes.
Dunno if that helps or not.
check my truck webp age in my sig line for pics.
-W
Woogeroo is offline   Reply With Quote
Old 05-10-2011, 01:48 PM   #4
Joemomma1
Joemomma1's Avatar
Not really, on the wedge piece that bolts the booster bracket to the firewall there are 3 philips head screw. I'm missing this but have seen them on my other 2 setups. I'm wondering what I can use, the back needs to be conical.
Thread Tools
Display Modes
