Old 05-09-2011, 08:33 AM   #1
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
brake trouble on the '62. little help, please?
Yesterday while driving through town, some idiot turned in front of me.
I had to slam on he brakes, hard enough the lock and skid.
When I went to take off, I noticed the truck pulling hard left.
After about a mile, the brake started smoking. I had to call a rollback.
I didn't get home until dark and never got a chance to check it out.
I'm not the worlds best mechanic, but I can't afford a huge bill.
My question: what exactly should I expect when I pull the drums?
Maybe just dirt and corrosion keeping the pads from retracting?
maybe a stuck piston. I'm just looking for your been there,
done that story. Thanks guys.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 05-09-2011, 08:58 AM   #2
awbrown
Re: brake trouble on the '62. little help, please?
First off if it still is stuck I would try driving it forward and back to see if it loosens up ,also brake the breeders loose to make sure you dont have a hose that has gone bad inside , if not you will have to try to back off the adjuster til it turns or you will be some frustrated tring to remove it with it locked up ... I am asumming it is a drum brake truck ?? if it is discs and it doesnt release upon braking the bleeders free , you should be able to pry the caliper off .......
awbrown is offline   Reply With Quote
Old 05-09-2011, 09:12 AM   #3
retodd7711
retodd7711's Avatar
A little more info. It's the front brake. Drum, not disc.
Brakes were working fine until the lockdown.
All three other wheels seemed to roll fine.
Truck rolled backwards off the rollback,
But would not roll forward without great effort.
Thanks, Todd.
She can't cook
So forget her.
My old farm truck
Old 05-09-2011, 10:52 AM   #4
Rich 5150 69
Rich 5150 69's Avatar
I don`t believe the 62`s had self adjusters... maybe wrong....I`m thinking more like a retractor spring broke...!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-09-2011, 10:55 AM   #5
slepysal
slepysal's Avatar
jack the end that has the problem, spin the wheel. Is it draging, or making any strange sounds? I would take the wheel and drum off and see if any thing broke or came loose. Keep us posted
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-09-2011, 05:22 PM   #6
Surfdaddy
Surfdaddy's Avatar
I agree with rich. sounds like a retractor spring broke. I just finished messing with the brakes on my 61, kind of a pain
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
Old 05-09-2011, 07:20 PM   #7
retodd7711
retodd7711's Avatar
Well. I had to beat the drum off with a big hammer.
The wheel cylinder was stuck open and wouldn't let
the springs retract. New wheel cylinder $20. Not too bad.
About half a can of pb blaster before I started turning bolts
Seemed like a good idea. Everything came off fine.
Thanks guys, always a big help in times of need
She can't cook
So forget her.
My old farm truck
Old 05-09-2011, 07:30 PM   #8
Surfdaddy
Surfdaddy's Avatar
Did you have to remove the backing plate to get the wheel cylinder off? On my 61 3/4 ton the wheel cylinders were called out to be the same from front to back but they weren't. I had to get a rebuild kit and put the old ones back in.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 05-09-2011, 07:36 PM   #9
slepysal
slepysal's Avatar
good to hear !
Old 05-10-2011, 04:39 AM   #10
retodd7711
retodd7711's Avatar
And I had a really cute helper
She can't cook
So forget her.
My old farm truck
Old 05-10-2011, 11:26 AM   #11
slepysal
slepysal's Avatar
And a cold brew? Life is good !
Thread Tools
Display Modes
