Old 05-11-2011, 10:59 PM   #1
taank
which sway bar?
looked at cpp's front and rear kit. $269
http://www.classicperform.com/Store/...ck/6372SBK.htm
or pol's front and rear $259
http://www.performanceonline.com/196...-SWAY-BAR-KIT/
any other reccomendations? i will be disconnecting the front one at the track but the rear will be on at all times. i'm just tired of it street driving like a wet noodle
taank is offline   Reply With Quote
Old 05-11-2011, 11:21 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: which sway bar?
im going to order the cpp kit next ,im waiting on the tubular arms it seams there a backorder on there shafts for the arms .
but i like the cpp my self .
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-11-2011, 11:47 PM   #3
taank
Re: which sway bar?
My rear coil spring cups are on back order too. 8 weeks out !!!!
Old 05-12-2011, 12:41 PM   #4
taank
Re: which sway bar?
Is there a dramastic advantage in having them? The c10 handles like a wet noodle in the corners. Looking at adding a front and rear and then disconnecting the front at the track. Is bigger better in sway bar size?
Old 05-12-2011, 05:01 PM   #5
OJ1988
Just a car guy
OJ1988's Avatar
Re: which sway bar?
World of difference on the street.
Rear may help at track also.
Generally bigger is better.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 05-25-2011, 01:58 PM   #6
taank
Re: which sway bar?
Seriously wtf. I waited forever for these cups and now I go to put them in and I have to make a run to the hardware store because the bolt supplied for the lower mount is 1.5 inches to short! Arrrrrrghhhgghghggh!!!!! Now I am very leery on getting anything else from them. It was supposed to be a complete kit.
Old 05-25-2011, 02:21 PM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: which sway bar?
A front sway bar is the best addition and bang for the buck you can make to your front suspension. New ones are fine but any front swaybar from a 1973/1987 Chev/GMC truck will bolt right in and there is a million of those trucks at wreckers. If you decide to go the used route try and find front bar from a 3/4 or 1 ton truck as I believe they are either 1 1/8" or 1 1/4" thick.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Thread Tools
Display Modes
