Old 05-13-2011, 10:40 PM   #1
chapster
chapster's Avatar
Quick question on lube for porterbuilt suspension
Hey Guy's,
Just want to see what everyone uses for lubing the delrin and polyurethane bushing. I assume due to delrin being self lubricating that a standard grease is fine but some state they use a graphite grease for polyurethane bushings.
Please advise....
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline   Reply With Quote
Old 05-14-2011, 09:55 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Quick question on lube for porterbuilt suspension
I wouldn't use a "petroleum based" grease. I have heard that Delrin can absorb petroleum based lubricants and it will cause it to swell up. I did a bit of research and couldn't find an official response on the Dupont website.
Maybe someone with more knowledge on the product can confirm my concerns.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-14-2011, 10:55 AM   #3
chapster
chapster's Avatar
Interesting,
I know I have used delrin on small automation machines that were always dry but I am not familiar with using them for automotive.
Old 05-14-2011, 01:46 PM   #4
m6z
m6z's Avatar
I think the Delrin is to be installed dry. Use a synthetic on the poly stuff. Either the Super lube you can get from UMI suspension or Mobil 1 which you should be able to get at your local auto parts store. I've also found the super lube at Harbor freight, so you might check there if you have one local. Energy Suspension makes a grease also, but is kind of pricy.
http://www.summitracing.com/parts/UPI-3008/?rtype=10
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 05-14-2011, 01:50 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Energy Suspension makes a silicone grease especially for poly. It is STICKY stuff, but works great and does not wash off easily...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-14-2011, 04:10 PM   #6
belowme51
belowme51's Avatar
This is from Porterbuilt:
It is important that a liberal amount anti-seeze lubricant be used on the areas where the bushing insert and lower control arm shaft come together. Also be generous on the long threaded through shaft that ties the lower control assembly together.
belowme51 is offline   Reply With Quote
Old 05-14-2011, 08:10 PM   #7
chapster
chapster's Avatar
Thanks for the info guy's, I have a asked Nate the question also.
As it stands now: Delrin-inside diameter = anti seize (graphite??)
Delrin - outside diameter = anti seize graphite??)
Poly - inside & outside diameter = silicone/synthetic grease
I would like conformation on this so I can be ready to assemble.
Old 05-14-2011, 08:16 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
Negative on the anti-seeze for the lubricating the Delrin. The anti-seeze will be for the metal to metal components on the lower shaft assembly.
The delrin goes together dry.
As for the poly use the stuff (or similar to) what energy suspension has.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-14-2011, 08:45 PM   #9
chapster
chapster's Avatar
Thanks for the clarification Nate. So automotive use with delrin is no different than when we use it on small automated machines (dry because of it's self lubricating properties)
As for polyurethane, I have never run them before and I did not want any squeaking.
hopefully I can find poly lube locally.
Thanks everyone......
Thread Tools
Display Modes
