1977 Heavy Half, what weight trailer can I tow?
The data decal on the door is pretty much unreadable.
I want to buy a travel trailer. How do I figure out what weight trailer I can pull? Last edited by PugDad; 05-14-2011 at 12:58 AM. |
One shot, one kill.
Re: 1977 Heavy Half, what weight trailer can I tow?
10,000 pounds with a good reciever type hitch, about half that with a bumper hitch. Either way toung weight will be about 500 to 800 pounds. I don't have a clue what a gooseneck will do, but I imagine it's up there, 15 or 20,000?? jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
Thank you, sir!
Which model do you have?
you realy cant over load a big 10, but you can improperly load one you also wanna check your brakes, shocks ect. before you try to haul that much
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod ![]() |
i wouldn't tow 10,000lbs with a half ton regardless if its a "heavy half" trying to stop is going to be your problem i would say 7,000 max.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
#8 | |
I'm actually looking at about a 4000 lb trailer, probably another 1000lbs load, so maybe 5000 lbs, give or take a couple hundred. |
my 76 says 6200 on the door tag, im fairly certain thats the number that makes it a big 10 but I could be wrong.
I towed with this setup for years and years; approx 4500 lbs counting the car and trailer.
My truck is a V6, manual, regular half ton - so you shouldn't have any problem with 4000 - 5000 lbs. K ![]()
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-14-2011 at 09:35 PM. |
#13 |
Which engine you got?
#14 |
#15 |
my 85 c10 with hd suspension from the factory can tow 12 on the bumper with about 1/2 ton of tongue weight. with a goose-neck you can tow much more as long as your brakes and wheels can support it. Remember any more than about 4 tons, its towing you
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
#16 |
If it's a 350, then the GVWR is 6200lbs. Not sure what the GCWR is.
But the other thing you can do just to be safe is to go to any chevy dealer's parts counter (could be any GM dealer, but probably best to go to a chevy dealer), give them the vin# and they can look up all the pertinent info on the computer----GVWR, GCWR, rear gear ratio etc. etc. |
#17 | |
Fourth digit in VIN is a 4, which as my understanding is the heavy half designator. Also, seems to be the 68th unit to roll off the line in Fremont. Where the heck is Fremont? Last edited by PugDad; 05-15-2011 at 12:30 PM. Reason: clarity |
#18 |
Californ-i-A.
So the sequence portion of the VIN is 100068-ish? Be advised trucks weren't necessarily built in VIN order (close, but not quite). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#19 |
![]() Join Date: Jul 2010
check tha vin in tha motor to see what you realy have
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#20 |
#21 |
Please don't tow 5 or 6 tons behind a half ton truck. Just because people say they have done it doesn't make it safe, legal, or smart.
You have small wheel studs (and less of them). You have little tiny load carrying bearings and you don't have a full floating rear axle. A heavy half might have a bunch of springs in the back, but it does not have adequate cooling to tow 10k, it does not have enough brakes (regardless of trailer brakes), and unless you upgrade your wheels and tires aren't up to it either. A trailer is on wheels, so of course you can pull on it and cause it to move. But there is far more than that to safe, responsible trailer towing.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
#22 | |
#23 |
Getcha Pull
Already been covered, but I figured I'd post this information for anyone who finds this thread in a search.
![]() Lowest Rated C10 = 4900lb (With Nothing...) Highest Rated C10 = 6200lb (With V8) Lowest Rated C20 = 6400lb (Standard/Regular Cab) Highest Rated C20 = 8200lb (Heavy Springs/Crew Cab) Lowest Rated C30 = 6600lb (Standard/Regular Cab) Highest Rated C30 = 10,000lb (Dually/HD Brakes)
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra Last edited by Altec; 05-17-2011 at 06:16 AM. |
#24 | ||
We need to find out what GCWR is on the truck. i'm not sure where to find it. Do you have your owner's manual handy? 4000lbs trailer with 1000lbs in the bed is actually kind of pushing it for a 1/2 ton, but let's do more research. P.S. GVWR= Gross vehicle weight rating. How much total can the truck itself, fuel, driver/passengers and load weigh. GCWR= Gross combination weight rating. How much totally can the truck(including above mentioned load) plus the trailer weight. Or something like that. There is probably a good link that describes all that, but i don't have time to find one. Last edited by C-10 simplex; 05-17-2011 at 01:38 PM. |
#25 |
No info in the owners manual
Thread Tools | |
Display Modes | |
