Old 05-16-2011, 12:08 PM   #1
ges55
BLACK SATIN
ges55's Avatar
won't idle
We put a 1985 305 V8 in my 67 3/4 ton that had a 250 6 cylinder. It didn't run very well until we rebuilt the carburetor, but it still won't idle. There is a tan wire with a black stripe on it that we're not sure where it went. I would appreciate any help with this. It is a Rochester quadrajet with an electric choke. The electric choke is working fine & it seems to run OK at higher rpms.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 05-16-2011, 01:53 PM   #2
ARTISTIC
Re: won't idle
From past experience it could be any of the following on a QJet:
Float adjustment
Primary blade / Choke adjustment
Idle mixture screws
Worn primary metering rods / jets
Vaccuum leak
Does it run rich or lean at idle? Ive had lean issues with choke closing the primary too early and killing the engine except at higher idle (both vac. pull off and electric).
ARTISTIC is offline   Reply With Quote
Old 05-16-2011, 02:58 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Re: won't idle
If the timing is too retarded it won't want to idle.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-17-2011, 08:35 AM   #4
ges55
BLACK SATIN
ges55's Avatar
Re: won't idle
It seems to be running lean.
Old 05-17-2011, 08:53 AM   #5
Wrenchbender Ret
Re: won't idle
You probably have a bad vacuum leak some where. There is a large vacuum outlet at the rear of the carb. If this is not utilized or plugged it will cause this. Start with the idle mixture screws about 3 turns out. Then slowly turn them in till the engine slows down. Then open them about 1/2 turn. Did you set the float level correctly? You may have to raise it a little.
Wrenchbender Ret is offline   Reply With Quote
Thread Tools
Display Modes
