Old 05-17-2011, 10:24 AM   #1
NevadaDVX
Question for those with chrome/billet grills
I've got a Tri-Plus complete billet grill assembly with steel chrome frame for my 71. The grill did not come with any hardware, although I heard it was supposed to. I purchased it well over a year ago, so it's too late to do much about it from the vendor I got it from.
Anyway, I got the grill brackets mounted, but need to figure out how to make an extension for the hood latch. Pics would really help if anyone has one of these.
Oh, and I am very dissappointed in this thing considering it ran almost $600 shipped. The chrome is peeling off the top and lower edges, not to mention the missing hardware.
NevadaDVX is offline   Reply With Quote
Old 05-17-2011, 10:55 PM   #2
NevadaDVX
Re: Question for those with chrome/billet grills
Anyone? I know there are a lot of guys on this forum with this grill.
Old 05-19-2011, 08:50 PM   #3
NevadaDVX
Dang! Nobody has one of these grills and can describe how the hood latch works???
This is the same grill I have.........
Old 05-19-2011, 10:49 PM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Question for those with chrome/billet grills
I took and made it where I can just get my fingers between the bars and open the hood. Most people can't though which is a good thing.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-20-2011, 08:58 AM   #5
Tim Christian
Tim Christian's Avatar
It should of came with the T-Bar that mounts to your hood latch handle. What other hardware was you looking for? Also if you don't mind me asking were did you buy it? Thanks Tim
Tim Christian is offline   Reply With Quote
Old 05-20-2011, 09:23 AM   #6
NevadaDVX
Tim, I had Wes at ClassicHeartbeat order it for me about a year and a half ago. I opened the box at that time to see what it looked like, but never took it out. It did not come with anything whatsoever except the grill, which I did not find out until I was ready to assemble it. I had to go to the hardware store and come up with some fake looking aluminum rivets for above and below the headlights. Plus I added stainless philips screws for the upper and lower portions of the side brackets. That all turned out fine.
I had called Wes when I found there was no hardware in the box a couple of weeks ago, and he said he usually comes up with his own anyway because the stuff that comes with it is cheap. He also said he makes his own latch extension. But I have no idea how the hood latch is supposed to work, which is why I started the thread. I don't have the truck here at the moment, as it is getting painted. I wanted to have everything ready to assemble when I get it back in the next couple of days.
The thing that really gets me about this, is while I was cleaning the protective film of grease off it, the chrome started peeling at the top, and a small bit on the bottom. I did not know this until after I talked to Wes about the hardware. But I doubt he can do anything now anyway. Either way, it is VERY disappointing. Hopefully the bumper will hide the lower portion, and the upper part won't be seen unless the hood is open, but it is a fairly large section and most likely will get worse.
Don
Old 05-20-2011, 10:07 AM   #7
Lemield
Lemield's Avatar
I put a billet grille in my 1970 CST....I HATED the handle that was supplied in the kit and decided to make a cable operated hood release....here is a link to what I did....
http://67-72chevytrucks.com/vboard/s...d.php?t=445343
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 05-20-2011, 10:19 AM   #8
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Don, I don't remember you saying anything about the pealing chrome. As for the hardware, I explained that the grill does not come with mounting hardware, I explained that I use stainless machine screws to mount these grills, because they look better than rivettes. I also explained to you that the grill comes with a "T" bar, but because it had been over a year I wouldn't be able to do anything about it. Too much time had passed. I explained to you how I make them and what you needed to buy at your local hardware store. Had you mentioned that the grill was peeling at that time I would have told you the grill is warranteed and would have made arangements with you to pick that grill up and have another one shipped to you.
Now, I have called Key Parts, and they will warrantee the grill, however I was also told they were out of stock at this time. Probably 6 weaks or so before they get any in. They do have the grills with 8mm bars in stock though. I do have another idea in order for you to be able to use the 4mm grill insert, but I will have to get that approved once I open my shop. You can call me after 9:00 am and we will work this out. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 05-20-2011, 10:22 AM   #9
Lemield
Lemield's Avatar
Yet another example of how Wes takes care of his customers!
Larry
Old 05-20-2011, 07:02 PM   #10
NevadaDVX
Thanks Wes. As I stated above, I did not know about the peeling chrome until after I talked to you and was just going to live with it, because I knew it was out of warranty. I noticed it after I had the brackets on and I was cleaning the protective grease film off with mild degreaser. I wiped the upper area and a large section of chrome just rolled up as well as a small section on the bottom. Like I said, this happened after I talked to you.
Yes, you did explain the "t-bar" thing. I was just hoping I could get someone on here to post a pic of what it should look like, how long it is, etc, to give me an idea or ideas of what to make.
I just got home from work and not sure if you are open on Saturdays, but will give you a call in the AM. For the record, this post is not a bash against you or your business which is why I never mentioned you until asked. You obviously have no control over parts issues as does any vendor. I am in the automotive trade as a body tech and realize how aftermarket parts can be difficult at times. Anyway, talk to you soon. Thanks again
Don
Old 05-20-2011, 09:15 PM   #11
Classic Heartbeat
No offence was taken, and I saw you hadn't mentioned our company. I usualy don't handle problems on the board, but my company was name was mentioned. So I was left with no choice. I'll talk to you in the morning. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 05-20-2011, 09:25 PM   #12
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
And yet another reason why I only shop with wes, although it has been awhile..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Thread Tools
Display Modes
