Old 05-18-2011, 03:17 AM   #1
doctrouble
doctrouble's Avatar
More 3/4 rear drum questions
Alright.. (taking 5 mins to condense my story).... OK!. Was using this awesome thread for research to replace my wheel cylinder .. http://67-72chevytrucks.com/vboard/s...d.php?t=283587 .. I bought the spindle socket with the 6 prongs on it. Its all good until this point. I found a huge nut after i took the shaft out. I tried using a large pair of channel locks to turn it. And DID seem loose but only maybe 1/16th of the circle. if that made sense ?*** Question is, do i just use my brute strength to turn it with the hopefully right size socket i bought for it?*** Just wasn't sure if there was another cotter pin like the front drums have that I'd rip in half if i just turned it.
Many thanks in advance.
First is right after i took the shaft out. Second is that nut. Third is the socket i bought.
"Feel it's not a bonfire unless they can see it from space?" ~ Capt. Morgan
1970 Cst - 20 402
1984 Chevy C30 6.2L Diesel crew cab Dualie
doctrouble is offline   Reply With Quote
Old 05-18-2011, 04:07 AM   #2
stsalvage
Scrapper 1
stsalvage's Avatar
Re: More 3/4 rear drum questions
If you look in side there is a washer with teeth legs on it that Keep it from backing off Use a flat blade screw driver and lift them up to clear the nut In my 1965 I have the same rear end and my has a nut with groves in it and yours dose not so All i can say is take a flash light and look in side to see if there is something that is catching the nut
stsalvage is offline   Reply With Quote
Old 05-18-2011, 04:28 AM   #3
doctrouble
doctrouble's Avatar
Thanks for the logical method of looking at it. I'll definitely take another look at it sometime as when it decides to stop raining, just started tonight.. :/
1970 Cst - 20 402
Old 05-18-2011, 01:14 PM   #4
dmack91
dmack91's Avatar
I thought the usually the tabs are bend around the inner nut to keep it from backing off, and the outer nut is a lock nut (been a while).
I just use a chisel and tap the nut loose.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 05-20-2011, 03:04 AM   #5
doctrouble
doctrouble's Avatar
Alright. Went to Target and used that as an excuse to get a sweet looking flashlight.. . It was dry out and tried that huge socket for the nut. Socket was a hair to small but was still able to wedgie it in to turn it. I didn't see anything with the flashlight so i bit it and gave it a turn. I guess it was just stuck on something... i hope.... and came right off. I also didn't need the spindle socket. Just for the reference mine was a 1970 cst20 and not a 1971 3/4 ton as mentioned in the above thread.
1970 Cst - 20 402
Old 05-20-2011, 03:26 AM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
hammer and brass drift will take them off to if you dont have the socket
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-20-2011, 07:32 PM   #7
cadillacart
1972 C/20
cadillacart's Avatar
Did something change on 72 models? I did not have to do any of this when I took my drums off. The drums are separate from the hubs on mine. Different Rear End?
Good luck!
My Gallery
1972 C/20 402
Gramp's Truck
cadillacart is offline   Reply With Quote
Old 05-20-2011, 07:39 PM   #8
john
member #16
john's Avatar
Good luck!
Yes the dana's have removable drums and corporate rears have inboard drums you have to pull the hub.
john is offline   Reply With Quote
Thread Tools
Display Modes
