05-20-2011, 10:57 PM | #1 |
6 lug to 5 lug axles?
i have a 1971 that has the suspension from a earlier 6lug not sure what year.
it is a 12 bolt rear end and i think it is from 67-70 range. can i just pull the axles from a 71 or later and slide them in to make the truck a 5 lug again or are the axles wrong length |
05-20-2011, 11:33 PM | #2 |
Re: 6 lug to 5 lug axles?
If I remember right the 71-2 axles are about 1/2 inch too wide, but speedway makes an axle conversion kit for like $500. Probably cheaper to just find a different rear end though.
77 CHEVY - SHORT BED STEP SIDE 2WD 02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT |
05-20-2011, 11:42 PM | #3 |
How wide is your rear end? no, no, no.... the truck's rear end
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
05-21-2011, 12:24 PM | #4 |
i just looked at the diff and these are the numbers i found
1234 67890 or maybe 67800 j48 and on the other side gm54 f3896838 i was told it is 308 gears. not sure how to decode this |
05-21-2011, 12:34 PM | #5 |
67-72 parts collector,…
The only 6-lug coil spring rearend housing that will accept 71-72 5-lug axles is the 1970 6-lug rearend.
They are the same width as the 71-72 rearends. The 67-69 6-lug rearends are approx. 3/4" per side narrower. Take a backing plate-to-backing plate measurement. 55.5" will not work. 57" will work.
05-21-2011, 12:38 PM | #6 |
ok will do
05-21-2011, 12:49 PM | #7 |
If you happen to have the "narrower" 6-lug rearend,... you have two choices:
1) swap out the entire rearend for a 71-72 rearend. 2) install aftermarket 5-lug axles. Look at Moser Engineering for aftermarket axles.
05-21-2011, 12:57 PM | #8 |
i think it is the narrower one i will check the website out thanks
05-21-2011, 05:20 PM | #9 |
check out CPP for conversion axles for the 63-69 55.5" axles, here is the info that I have for the axle set
conversion axle set 67-68 part number 6369rac-5 price $289 website link http://www.classicperform.com/Store/.../6369RAC-5.htm thats the axle set that I have purchased for my build. I am currently in Afghanistan, so I have not had the opportunity to verify the fit. had some long talks with customer service about the axles, and he assured me that they would work. keep us informed
A C Ward Retired US Army 66 El Camino 67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475 |
05-21-2011, 07:47 PM | #10 |
i found a junk yard that sells the rearend from any truck for 125.00 and i have to pull it .
dont know if they have one of the trucks i will have to see. |
05-21-2011, 09:24 PM | #11 |
I bought my conversion from Early Classic and all I to do is get a drums and a rebuild kit and the rear was done.
71 Chevy Stepside 377/350 Last edited by 71STPSDE; 05-21-2011 at 09:26 PM. |
05-22-2011, 08:40 AM | #12 | |
Summit has Mosers alloys in stock for $244 a set Brand Moser Engineering Manufacturer's Part Number A30-70GMT2 Part Type Axle Shafts, Direct Fit Product Line Moser Engineering Replacement Alloy Axle Shafts Summit Racing Part Number MSR-A30-70GMT2 Inner Axle Splines 30 Axle Length (in) 31.313 in. Axle Material 1541H alloy steel Wheel Stud Pattern 5 x 5.00 in Wheel Stud Type Press-in Wheel Studs Included No Bearings Included No Seals Included No Quantity Sold as a pair. Spike
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
05-22-2011, 10:04 PM | #13 |
I got my kit from brothers. At first I cut down the stubs and re-drilled the flanges and drums on my 6 lug axles but after all that work(I wasnt totally happy with the results) the kit seemed like a steal. Does anyone know what these type kits use for drums? They seem like 73-87 drums.
03-08-2012, 11:34 PM | #14 |
BACK up....
Thread Tools | |
Display Modes | |
