Old 05-23-2011, 11:57 AM   #1
KazuyaIB
A/C Pressure build up
I have a 86 chevy that just is possessed and does not want A/C. If i turn on the truck and let it idle with the A/C on, pressure builds up and the compressor begins to spit out the excess pressure through the safety valve. I am wondering if it is a wiring issue or just the evaporator needs a fan. Never have had an issue of this kind. Pretty stumped.
KazuyaIB is offline   Reply With Quote
Old 05-23-2011, 06:14 PM   #2
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: A/C Pressure build up
Is it cooling? Could be the metering orifice stopped up.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 05-23-2011, 09:16 PM   #3
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Yeah.. does the vent temp get cold?? Possible that your cycling switch is bad, and it won't cycle off the compressor, so it's using a secondary safety measure by relieving pressure elsewhere...
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 05-25-2011, 05:41 PM   #4
KazuyaIB
Well the problem is that i have gotten it work for a while. The problem like i said is that if I idle the pressure builds up and all heck breaks loose. I will change the cycling switch and see what happens. The other day i put in a compressor and with a single can of freon the a/c hose blew up. Alot of pressure build up. I did change the evaporator and condensor. Compressor seems fine.
Old 05-25-2011, 07:16 PM   #5
85gmcguy
Plays with trucks
85gmcguy's Avatar
Did you pull a good vacuum on the system before you charged it? The orifice still could be causing a problem if it's full of gunk nothing can get through, just like a stopped-up drain. It's easy and it's cheap insurance.
Gary
My Dad's Old Truck
1985
Old 05-26-2011, 09:44 AM   #6
Desert1957
Desert1957's Avatar
Your system has some type of restriction. needs to be flushed with proper a/c chemicals , blown out , new orifice tube , evacuated , new accumulator , proper charge of oil and freon.
Installing new compressors on clogged systems is a risk , can be damaged by circulating trash in the system.
Desert
Desert1957 is offline   Reply With Quote
Thread Tools
Display Modes
