Old 05-23-2011, 10:22 PM   #1
coops714x4
coops714x4's Avatar
NV 4500 swap questions
ok guys I am wanting to put a NV4500 in place of my sm465 I have found out all the 4X4 swap info NOW will it bolt up to a stock chevy bell housing and can I use a mechanical throw out bearing I really dont want to run hydrolic clutch
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
Old 05-23-2011, 11:27 PM   #2
treveiger
treveiger's Avatar
Re: NV 4500 swap questions
you just need a adapter plate for it to bolt up to your bellhousing and you can keep your mechanical clutch. I had a thread on it a while back if you check my threads started it should show you what adapter plate and what nv4500 to use(from a dodge truck).
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 05-24-2011, 12:29 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=415769
LockDoc
Leon
Old 05-24-2011, 12:53 AM   #4
treveiger
treveiger's Avatar
Thank you lock dock I was just trying to find it but then saw it up here already
Old 05-24-2011, 02:06 AM   #5
coops714x4
coops714x4's Avatar
if I have to use a dodge tranny Ill just keep my sm465 why wont a chevy nv4500 bolt up did they change bolt patterns ??
Old 05-24-2011, 11:43 AM   #6
treveiger
treveiger's Avatar
You can use a Chevy tranny but you'll need a new bellhousing that is more expensive than the adapter and will require a transmission crossmember also. There the same transmission for the most part just different bolt patterns and some have higher 1st gears
Old 05-24-2011, 04:54 PM   #7
coops714x4
coops714x4's Avatar
I called advanced adapter today and they have a kit that includes everything but the clutch and pressure plate it even has the adapter for my np205 so thats the way Im gonna go as far as the crossmember I have one from a auto tranny that I can modify if I need to
Old 05-24-2011, 05:01 PM   #8
treveiger
treveiger's Avatar
Sound great! A guy named jjorgeson I think was his name on here did a swap like what you want to do and posted a thread on how to.
Old 05-24-2011, 05:05 PM   #9
treveiger
treveiger's Avatar
Here it is.
http://67-72chevytrucks.com/vboard/s...d.php?t=429413
Thread Tools
Display Modes
