Old 05-26-2011, 06:34 AM   #1
kgmunro
steel wheel question
Any one know what larger steel wheel will bolt on a 5x 4.75 bolt pattern? I have a camaro clip and rear diff but want some where aroud 18 -20 in ch steel wheels. Just wondering if anyone has found any auto wrecker wheels that will work.
kgmunro is offline   Reply With Quote
Old 05-29-2011, 12:11 AM   #2
mr48chev
mr48chev's Avatar
Re: steel wheel question
Any steel wheel intended for a Camaro or Chevelle will fit. A lot of the GM mid size rear wheel drive cars use that bolt pattern.
If you have a connection with a tire store that sells a lot of custom wheels you might ask about take off wheels. Sometimes you can get a deal on a set of almost new factory wheels and tires for a lot less than you would pay for the tires normally. Or if there is a car dealship or used car dealer that always seems to have hot lick late model cars on the lot with oversize custom wheels and tires. They may have take offs in the back room that you might be able to work a deal on.
Old 05-29-2011, 12:23 AM   #3
daverod
SSN 706
daverod's Avatar
http://www.discountedwheelwarehouse...._Reference.cfm This helped me.
daverod is offline   Reply With Quote
Old 05-29-2011, 01:33 AM   #4
fredscarryall
fredscarryall's Avatar
the 2010 camaro has a 18 inch steel wheel it only 7 1/2 wide and bolt pattern is a 5 on 120 (which i believe is a 5x4.75) .but as soon as you say camaro and 2010 you will more then likley pay $100 per wheel (to buy them new is about $300 each and most wrecking yards know that).wheel vintiques is also planning on making the gennie wheel in a 18s but it will only be 7 inches wide. not sure if it out yet.but they will be a custom order.the on line catolog is being reworked so you will have to call them.they are rumored to be $100 or more. there are late model dodge rims in 18s to 20s.like 2002 to 2008 dodge 1500 spare tire wheels that are 20 inch and 8 wide. they are pretty cheap and i have seen a couple of trucks at the car show with them and they looked good. but you would have to get a wheel spacer adapters on ebay. or get a machine shop to redrill your rotors and axles. but thats about $200 and the time to pull your rearend apart to get the axles.or even get the wheels redrilled. other then that, i have not seen any others out there and i have been looking on the internet for years. also try stockton wheel but they are under new ownsership,so who knows what they will put out
4
fredscarryall is offline   Reply With Quote
Old 05-29-2011, 01:40 AM   #5
fredscarryall
2002 to 2008 dodge 1500 steel 20s and 8 wide. the bolt pattern is a 5 on 5 1/2
Old 05-29-2011, 01:44 AM   #6
fredscarryall
2010 camaro rim in 18 and 7 1/2 wide. bolt pattern is 5 on 120 (5 on 4.75)
Old 05-29-2011, 01:48 AM   #7
fredscarryall
wheel vintiques gennie in 18 steel wheel.my or may not be produced. will be 7 inched wide and in various bolt patterns.
Old 05-29-2011, 02:00 AM   #8
fredscarryall
hopefully others can come up with more wheel ideas.i am suprised that hardly any companies are making steel wheels in .18s 20s and even 22s. because it seems everyone wants big wheel now a days.
Old 05-29-2011, 06:11 AM   #9
kgmunro
I love the look of that wheel vintiques wheel fredscarryall.
Old 05-29-2011, 09:35 AM   #10
Dan in Pasadena
Dan in Pasadena's Avatar
Hmmmm...I wonder what this could look like painted or powder coated with clips installed for one of the 50's dog dish hubcaps? I think it MIGHT look great. Anyone here have the Photoshop chops to give us an idea?
Dan in Pasadena is offline   Reply With Quote
Old 01-27-2012, 11:29 PM   #11
Big Irish
Big Irish's Avatar
How wide a wheel can you put on a 51 guys without adding inside wheel tubs ? Thx
1955 Chevy 2 door Wagon
1967 Short Wide BAGGED Gone to someone else
1953 Shop truck Clipped and Snipped sold
1951 GMC Bagged and patina
Big Irish is offline   Reply With Quote
Old 02-26-2012, 01:23 PM   #12
focusedontheprize
focusedontheprize's Avatar
Did you find the answer to this? I would also be interested.
focusedontheprize is offline   Reply With Quote
Old 02-26-2012, 02:42 PM   #13
Detroit3100
not much. I have some tiny mock-up wheels and a camaro rear and I am going to have to tub the bed sides.
Detroit3100 is offline   Reply With Quote
Old 02-27-2012, 12:16 PM   #14
G&R's57GMC
G&R's57GMC's Avatar
And then there's Year One with 17" billet or cast wheels for the Camero/Firebird . I know its not what your looking for but I thought someone might be interested. They also have the snowflake wheel for the Firebird 17x9 cast $199.
G&R's57GMC is offline   Reply With Quote
Thread Tools
Display Modes
