Old 03-30-2003, 03:33 PM   #1
mikep
Used to have a truck
mikep's Avatar
I wimped out
I pulled the 5.14 gears out of my truck and intalled 4.57's this morning. Its more driveable now. I'm a wimp.
No truck :-(
mikep is offline   Reply With Quote
Old 03-30-2003, 03:39 PM   #2
racedvl
racedvl's Avatar
LOL, what good is a truck if you can't drive it? Hehe.
racedvl is offline   Reply With Quote
Old 03-30-2003, 03:50 PM   #3
crazy longhorn
Fabricate till you "puke"
5.14 is a lot of gear,even with a tall tire! How do the 4.57s feel?
crazy longhorn is offline   Reply With Quote
Old 03-30-2003, 05:02 PM   #4
gmc67swb
gmc67swb's Avatar
4.57 IS ALOT OF GEAR!, I'LL BET YOUR IN TOP GEAR BEFORE YOU CAN GET THROUGH AN INTERSECTION (DRIVING CASUALLY)
I'VE RODE IN A CAR WITH 4.30'S. FIRST GEAR IS VIRTUALLY NON-EXISTANT, YOU'RE THROUGH IT SO QUICK.
HAVE FUN WITH THEM!
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 03-30-2003, 05:11 PM   #5
crazy longhorn
tire size makes quite a difference on gearing tho. With the 32" tall tires that Mike is running, the 4.57s shouldnt be too bad. I run 4.10s with a 28" tire, & they are a tad low on the hyway, but not bad in town.....crazyL
Old 03-30-2003, 05:20 PM   #6
Class of 69
Class of 69's Avatar
Nothing wimpy about admitting you"might" have made a mistake. Racedvl is right, if we all knew exactly what to do with our trucks the first time, we wouldn't need this board!! Enjoy
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 03-30-2003, 05:32 PM   #7
mikep
mikep's Avatar
From the beginning I "thoughT" the 5.14's might be too much gear but since I had them I figured I give them a shot try them out. Didnt cost me more than 3 quarts of oil and some silicone sealant and a couple of hours of setup time. I'm actually becoming pretty good at setting backlash on these eatons . I wouldnt have to do that each time but I have 3 pumpkins and only one detroit locker unit so every time I pull the carrier I have to break open the differential to install the locker and then reset the ring to pinion backlash.
I do run 32 inch tires and while 5.14's and 4.57's might seem like a lot of gear for a car running 27 inch tires I can assure you its a different world with big tire trucks. I once bought a car that had 27 inch tires and a 4.56 geared detroit locker 9 inch. I was miserable and ended up going to 4.10's! These 4.57's in this truck with the 32 inch tires are very driveable. I think I'l stay with them.
No truck :-(
Old 03-30-2003, 05:42 PM   #8
mikep
mikep's Avatar
I do have to say something about detroit lockers. They are the only way to go ! Ive used traction control devices of all sorts over the years . Clutches wear out or slip on one side and they torque steer to the right. Detroit lockers last forever and track straight and true every time. The locker in my truck was manufactured in 1959 and to look at it you coulnt tell it wasn't made last year . I have no idea what people are talking about when they say they make a ratcheting sound around corners. If they do so what but I can't hear it. They do chirp the tires a bit when they unlock but thats just fine with me. Every time I hear that chirp it brings a smile to my face .
No truck :-(
Old 03-30-2003, 07:08 PM   #9
casey
casey's Avatar
I'll tell you what wimpin out is mikep is when your scared to take the diff cover off, I don't really know didley squat about diffs. so swapin diffs ain't wimpin to me
casey is offline   Reply With Quote
Old 03-30-2003, 07:51 PM   #10
Truckstr
Truckstr's Avatar
I hear that, casey. I'm not too much (yet ) on diffs (started to say rearends - I'm an expert there ). I've been dinking around with them for years, but never set one up.
Hmmm. Might have to put that new dial indicator to work.
Jeff
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 03-31-2003, 08:26 AM   #11
Solver
Solver's Avatar
Next time I would suggest you video tape the process with some explanation as you go. I'm sure alot of us would purchase a how to tape.I have never done that but if I could watch someone else once, I wouldn't be so nervous about trying it myself.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 03-31-2003, 09:38 AM   #12
Edmond
Edmond's Avatar
Mikep,
Since you are becomming an Eaton expert on this board ,
can you tell me if an No Spin Rear Axle is the same as an Detroit Locker ?
I have the No Spin Rear Axle according to my glovebox.
Thanks in advance.
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 03-31-2003, 10:46 AM   #13
Yukon Jack
Post Whore
Yukon Jack's Avatar
Yep, a No Spin is the Detroit Locker.
As for the ratcheting, I also don't hear that, but I do get a noise every once in a while when I drive my truck that is definitely the locker loading or unloading - was very alarming until I figured out it was not a problem.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-31-2003, 10:56 AM   #14
Dean
Dean's Avatar
I have lockers in all of my K20s and I have noticed that the automatic trucks don't make as much noise. I wonder if the automatic trans absorbs some of it? Nothing beats the detroit locker. I agree on that. You can get in trouble with one though. If you have lots of power and nail it during a turn you better hang on....lol. My dad made this mistake with a Cobra back in the old days and through a fence he went...
I'm running 4.57s with 35" tires on mine. It drives fine but you won't be setting any salt flats records.
I actually have one center section with a 6 something gear in it. I think I might be able to pull trees out with that one. It was out of a GM panel van.
Dean is offline   Reply With Quote
Old 03-31-2003, 10:58 AM   #15
Nova_Cobra64
Nova_Cobra64's Avatar
Well, I'll put it to you this way, at least you have the option to swap gears. I wanted to replace my 3.08s with 3.73s, but since I can't do it myself, my Dad figured it would cost me between 5-600 when all was said and done.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 03-31-2003, 12:05 PM   #16
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Man, speaking of diffs....I got up the nerve yesterday to pull the cover on my cutlass to investigate that clatter noise it came up with the last few times I drove it........the frickin' pin let go and was smackin' the pinion head.......ack......oh well, I've been looking for an excuse to put a posi in it anyway.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 03-31-2003, 12:27 PM   #17
mikep
mikep's Avatar
Its not that hard. You can do it yourself in a pinch with hand tools ( although you may want to rent a big impact for the crush sleeve ) and a few common measuring tools. feeler gauges can sub for dial indicators and prussian blue for pinion depth gages. If you want to do it all by the book you can buy a setup kit, a dial indicator and a inch lb torque wrench for less than what most shops charge for an install. Then you can have the tools to keep and maybe even make money with on the side doing work for friends and other cheapskates
No truck :-(
Old 03-31-2003, 01:16 PM   #18
lpaine
lpaine's Avatar
Thanks for the inspiration, Mike. I have an Eaton diff in my 69 with 4.57s, I want to change to a higher set of gears I seem to remember someone saying 3.54s were as high as you could go on the eaton 10 bolt. I think I may just attempt this job myself, always wanted a dial indicator! Anyone know if 3.54s are as high a gear you can get for the eaton?Thanks in advance.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 03-31-2003, 02:06 PM   #19
mikep
mikep's Avatar
Iv'e heard of some 3.70's or some 3.73's but apparently they are exceedingly rare if not nonexistent. I dont think there werre any 3.54's available for the eaton although with OLD chevy trucks you might find something. They made these as far back as '52 but in the old chevies they compensated for lack of engine power with low gears in their 3/4 and one tons so high gears might be difficult to find. I know there are or were 3.90's available aftermarket.
Ive got a good set of 4.11's I was going to put up on the for sale board if you are interested.
No truck :-(
Old 03-31-2003, 03:23 PM   #20
Edmond
Edmond's Avatar
Thanks!!
Cya,
Edmond
The Netherlands
Old 05-17-2003, 10:08 PM   #21
kiley
mikep I solute you. That stuff is scary. BTW I want to thank you for your many posts on Eaton axles. I bought my truck without knowing what I had. Turns out I have an Eaton and have learned much about it thanks to you.
kiley is offline   Reply With Quote
Old 05-17-2003, 10:17 PM   #22
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Mike did you get something else or did you keep that beautiful truck????
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-18-2003, 12:46 AM   #23
Roberty
Hot Damn - Here I Am!!
Roberty's Avatar
Me personally, I wouldn't want to go lower than a 3.08. I owned a beater '70 a couple of years back that had a 4.11 or a 4.56 in it and I hated it out on the interstate. Sounded like it was about to blow up at 70mph or more. I'll stick with the 3.08's on my '71 - Love to be able to run up to the century mark without feeling like it's about to blow!
A 700R4 would be sweet.
Robert
My vehicles:
'90 Silverado Sport
'71 Chevelle SS Convertible
'70 C-10 - My Grandfather bought it new - original un-restored
Roberty is offline   Reply With Quote
Thread Tools
Display Modes
