Old 05-30-2011, 04:20 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Video of spinning my front left wheel off the ground..
http://s289.photobucket.com/albums/l...0530111225.mp4
I hope the link works.
Trucks jacked up, shouldnt the tire spin more 'freely' than this?
New soft lines, new hard lines, new 71 MC for disc drum new booster etc etc new calipers
Im stumped.
John
1999 Toyota Tacoma 4x4
Old 05-30-2011, 04:33 PM   #2
lakeroadster
Re: Video of spinning my front left wheel off the ground..
Doesn't seem to extreme to me. Drive it, check it to see if it gets hot.
lakeroadster is offline   Reply With Quote
Old 05-30-2011, 04:38 PM   #3
oldblue1968chevy
Does it seem like they are dragging? I only have about 25000 miles on the truck since I bought it (droev it awhile before I went disc).
Im on my 2nd pair of rotors and these ones are grooved really bad.
John
Old 05-30-2011, 05:14 PM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
Looks like a little too much drag to me, How many miles did you get out of your first set of rotors ?
Have you tried cracking the bleeder and see if it frees up ?
Compressed the caliper with a C-clamp and see if it frees up ?
Any chance you have the bearings adjusted a little too tight ?
How did you convert to disc, A aftermarket kit or OEM parts from a newer truck ?
Sorry for all the Q's.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 05-31-2011, 01:09 PM   #5
oldblue1968chevy
New parts/and parts from autozone etc etc etc (autozone, advance, orielly etc).
The bearings COULD be too tight, but I can hear it screech past the pads every rotation.
I'll crack the bleeder next chance I get and see what happens.
John
Old 05-31-2011, 03:46 PM   #6
Custom 68
Custom 68's Avatar
somebody remind me but doesnt the drum brake porportioning valve keep some residual pressure in the line? did you change this at the time you did your swap?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 05-31-2011, 08:26 PM   #7
oldblue1968chevy
Its a relatively new brass disc/drum prop. valve.
Maybe its not bled corrrectly or enough? Ive replaced parts so many times its not funny.
John
Old 06-01-2011, 11:57 PM   #8
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
If I were you i would take the wheel off and take the brake caliper off. spin the rotor... does it spin easily or does it drag and stop like in the video.. if it drags like in the video, you probally overtightened the center bearings. What can cause excessive wear on the bearings and spindle.
If it spins freely put the caliper back on and press the brake to get the pads close to the rotor... does it stop like in the video? if so your caliper might be sticking or maybe the pads are incorrect like they are to thick or something. start with the basics or start replacing random parts for no reason...
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-02-2011, 02:17 PM   #9
oldblue1968chevy
If I recall correctly, it spins freely with the caliper off. I REALLY wanna try to make some time to work on this. Im doin hay today its hot and im tired.
You guys can walk me thru all of this I just gotta get out there.
thanks!
John
Old 06-09-2011, 09:09 PM   #10
oldblue1968chevy
Stripped bleeder, broke the front line just below the prop valve to let fluid out. Still tight. Separated MC and booster and nothing. Squeezed the caliper and it spun freely.
Its NOT an over tightened wheel bearing nut.
Maybe the wrong brake pads or something?
Also, the inside of the rotor is grooved alot, the outside isnt, what the heck is going on?
thank you
John
Old 06-09-2011, 10:27 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Sounds like a bad caliper.
Keith
Convert to disc brakes.
Old 06-09-2011, 11:13 PM   #12
209jose71
thats whats it sounds like ^^^^^^^^
209jose71 is offline   Reply With Quote
Old 06-09-2011, 11:25 PM   #13
oldblue1968chevy
But ive replaced calipers multiple times, both sides?!
John
Old 06-09-2011, 11:36 PM   #14
209jose71
u rebleed the whole system right is there a new master in there
Old 06-09-2011, 11:49 PM   #15
oldblue1968chevy
New MC for like the 2nd time. (really tierd of buying parts that dont help anything.)
Im going to re bleed in the near future and go from there.
Problem is my FL bleeder screw is stripped (tried standard then metric then I was like heck i'll just bust it loose with some vice grips real quick...... ) Now its stripped all to h$%*!!!
Cheap friggin' metal is what it was made of!
John
Old 06-10-2011, 01:25 AM   #16
209jose71
maybe a pinched line take the nipple off both side up front see if one leaks more than the other one
Old 06-10-2011, 01:35 AM   #17
WORP67
I have also seen a stopped up hose do this. Causing the caliper to stay compressed somewhat it wouldnt let all the pressure back off when you let go of the brakes. Once I replaced the hose it freed up.
WORP67 is offline   Reply With Quote
Old 06-10-2011, 01:59 AM   #18
y5mgisi
Second Chance Program
y5mgisi's Avatar
MAybe im high but i think thats pretty normal.
y5mgisi is offline   Reply With Quote
Old 06-10-2011, 07:38 AM   #19
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
well, it's hard to tell from the video but I'm with lakeroadster and y5mgisi (if indeed y5mgisi is referring to the video and not his state of mind) on this. it's my understanding (quite possibly wrong) that disc brakes don't "retract" like drum shoes do. they release pressure, yes (if your's weren't, you wouldn't be able to move the wheel) but they don't pull away, instead relying on the small wheel wobble to create clearance.
my guess is that when the new pads wear into the grooves in the rotor it'll free up more.
is the bleed screw pointing down or up?
Larry
fleetsidelarry is offline   Reply With Quote
Old 06-10-2011, 11:09 AM   #20
oldblue1968chevy
I think it should've 'worn in' by now. I drive it everyday and did the converison 2 years ago..
John
Old 06-10-2011, 11:10 AM   #21
oldblue1968chevy
new braided hoses from ECE too
John
Old 06-10-2011, 12:32 PM   #22
WORP67
Is the caliper sliding freely on the bolts or could it be freezing up?
Old 06-10-2011, 12:36 PM   #23
oldblue1968chevy
What do you mean WORP67?
Ive had it on off quite a few times...still the same.
It seeemed to get better when I bleed my brakes and put a new MC on... (6 months ago, same problem)
John
Old 06-10-2011, 01:14 PM   #24
WORP67
I am not sure which calipers you used but some have bolts that slide into the caliper bracket and others have studs on the caliper bracket that the caliper slides on. If those get dry the caliper can seize on them. Causing the caliper to stick and can cause this.
Also did you use the 1" or the 1 1/4" rotors? did they give you the correct pads and calipers to match the thickness of the rotors? Some of the swap guides mention both thicknesses of rotors.
How much heat it coming from it when you stop? Does the other side do this or does it spin freely?
Old 06-10-2011, 02:48 PM   #25
oldblue1968chevy
I wanted to check both sides out last nite but didnt have room on the other side so I said forget it and went inside.
I believe I have the 1.25" rotors, I assume I have the right pads/rotors combo...
I guess I could take them back 'under warranty'? (Lifetime I think).
Im using 1971-1972 calipers (I cant remember which year exactly).
Caliper bracket?...Im using 71 72 stock spindles..
John
Thread Tools
Display Modes
