06-03-2011, 11:38 PM | #1 |
Wheel fitment for stock '69 with six-lug
I've been lurking for a while, and I hope you don't mind if post #1 is a question. My '69 is stock with 15" six-lug wheels and 1/2" studs. Are there any gotcha's I should know about for fitting replacement wheels? Will the hole sizes work with my 1/2" studs...a search led to believe there might be an issue - if special lug nuts are needed where can I get them?
Summit has several candidates in my low budget price range, including this one from US Wheel: http://www.summitracing.com/parts/USW-55-5760L/ Its specs are: 15X7 4.25" backspace +6 mm offset 4.28 center diameter 60 degree conical lug seat Will that fit? I want something that is inexpensive and will fit with minimal hassle. Thanks Bob Last edited by Custom Sport; 06-03-2011 at 11:39 PM. |
06-03-2011, 11:53 PM | #2 |
67-72 parts collector,…
Re: Wheel fitment for stock '69 with six-lug
Your stock lug stud size is 7/16", not 1/2".
A 15x8 wheel might look better on a stock truck.
06-04-2011, 02:55 PM | #3 |
check out the wheel vintique also, at summit they have a slightly different back space-i'm not sure but i think that more back space =wheel sets farther in the wheel well. depending on what size tire you use, you might consider 15x8's. also if you want to finish them off the caps and rings seem to be a rip off-at least to me. wont be buying them for mine.
06-04-2011, 04:35 PM | #4 |
Old Skool Club
Here's a pic of my truck, when it was assembled. It has Wheel Vintiques 15x8 on the leading edge and 15x10 on the hiney. Front wheels have a 4-inch backspace, while the rears have a 5-inch backspace.
The rear track on the 60-69's is about an inch narrower than the '70-up. On the front of my truck, I do have the ECE disc brake conversion, and that adds about an inch to the width of the track on that end. The bottom pic shows that they do not extend past the sides of the wheel openings.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 06-04-2011 at 04:36 PM. |
Thread Tools | |
Display Modes | |
