Old 06-06-2011, 08:38 PM   #1
chevylookin
230 Rebuild? Is this normal???
Hey guys, recently had my 230 rebuilt. First off, Im not a performance engine know it all by any means and just wanted to keep my little 230 for gas efficiency in mind but I had built up a lil. I had a 272 cam installed, lumped the heads, bored it .30 over and installed roller rockers. I gave it to the engine rebuilder and when I got it home and took the plastic off to install the oil pump and covers and what not, I found that the two valves that where under compression looked a little strange. The two lifters under compression are sticking almost 1/2 an inch out of their bores. (hydraulic cam I am almost 99% sure) I just gave these specs to the engine rebuilder and gave him gobbles of money and let him do the work, and presto! I expect a perfectly rebuilt engine back, right? Is this normal??? Are the lifters suppose to move up and down out of their bores like this??
chevylookin is offline   Reply With Quote
Old 06-06-2011, 09:45 PM   #2
boucher racing
boucher racing's Avatar
Re: 230 Rebuild? Is this normal???
I wish I could tell you. I just had my 250 built up. I did not check if the lifters do this. I can tell you can help you. Post this exact message over at:
www.inliners.org
Its a bunch of inline guru's. They will help you, 'fer sure!
Boucher
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 06-06-2011, 09:53 PM   #3
chevylookin
Thank you Mr. Boucher, I will!!
Old 06-06-2011, 10:16 PM   #4
chevylookin
Boucher~ I cant find anywhere where they have a forum available....
Old 06-07-2011, 12:35 AM   #5
HEI451
I'd say those two lifters were up on their cam lobes, open, as they should be. Now, IF the engine is at TDC on cylinders 1 and 6, then, one set of lifters will be equally all the way down in their bores, the other pair will be raised up a very small bit, equally.
From what I see in the picture, nothing looks wrong, but I do not know where the 1 and 6 pistons are, and from the picture, I ASSUME they are not all the way UP in their bores.
It is easy to get the 1 and 6 pistons all the way up in their bores, take a spark -lug out, doesn't matter if it is 1 or 6, use a flashlight to look down the plug hole and rotate the crankshaft until you see the piston stop moving UP inside the engine, then, go take a look at those lifters, 1 and 6 cylinders.
HEI451 is offline   Reply With Quote
Old 06-07-2011, 12:38 AM   #6
boucher racing
FYI. For future reference this forum or bulletin board as they call it is a wealth of information for inlines
http://www.inliners.org/ubbthreads/ubbthreads.php
"Cropwell" 66 C10
Old 06-07-2011, 01:33 AM   #7
HEI451
I convert points distributors to HEI, real HEI, but have 40 years of engine and drive train experience, at factory tech level. I also design/revise engine packages for Ducati Corse in the MotoGP race team division. My rider and I just moved form 6 years at Yamaha MotoGP, to Ducati, now, Ital rider, Ital bike, Ital fans are going bonkers. I am very glad to be Irish.
Old 09-10-2012, 07:39 PM   #8
rockdogg2020
How is your fuel economy with that setup
rockdogg2020 is offline   Reply With Quote
Thread Tools
Display Modes
