Old 06-17-2011, 04:11 PM   #1
factoryorange3
factoryorange3's Avatar
Harmonic balancer
Hi, i have a 1979 chevy inline 6. 250 ci. i recently did all new seals and gaskets in the motor and uppon taking the harmonic balancer off to do the front oil seal i discovered that the seal had warn a grove into the balancer. i went to the local napa and ordered a speedy sleve to fix the problem. to put the balancer back on the crank shaft i had to drive it on with a hammer because the crank is not drilled for a bolt. once i drove it on untill it stopped it had verry little clearance to the timing gear cover, and the belt didn't align properly. i am wondering if there is a certain spacing or if i just pull it out until it matches with the water pump pulley? any help would be great guys.
thanks, Ben
factoryorange3 is offline   Reply With Quote
Old 06-17-2011, 09:23 PM   #2
hugger6933
Re: Harmonic balancer
You had the right idea pull it out to square it up with the w/p. Jim
hugger6933 is offline   Reply With Quote
Old 06-21-2011, 06:56 PM   #3
factoryorange3
i did exactly that . thanks
Thread Tools
Display Modes
