06-20-2011, 10:36 PM | #1 |
Rear diff ID
I looked everywhere and can't seem to find much out about my rear end. It has 14 bolts. It's in a 72 BB TH400 3/4 ton pickup. Any help would be great.
06-20-2011, 10:52 PM | #2 |
Re: Rear diff ID
Also, it's a full floater. Is there any way to tell what the gear ratio is from the numbers in the pictures or do I have to do the old lift one tire and spin trick?
06-21-2011, 10:08 AM | #3 |
Re: Rear diff ID
Bump. Does anyone know if it could be correct to the truck?
06-21-2011, 12:11 PM | #4 |
Re: Rear diff ID
It looks like a corporate 14 bolt to me. I don't know when they started using but I know1973 - 1987 3/4 and 1 tons had them.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! Last edited by dougminton; 06-21-2011 at 12:11 PM. |
06-21-2011, 12:41 PM | #5 |
Re: Rear diff ID
It would have come with a Dana60 with 3.54:1 ratio. That looks like a 14-bolt from what I can see,which would have been swapped-in at some point. The Dana 60s have a drain plug in the lower right of the cover,doesn't dip in the bottom center as much,and has a more defined raised flat area at the ring gear.
06-21-2011, 02:02 PM | #6 |
Re: Rear diff ID
Thanks for the help guys. From what I can find it seems like a stout rear end.
06-21-2011, 02:20 PM | #7 |
Old Skool Club
Re: Rear diff ID
Don't know if your rearend has the markings that mine does...and it is just a 12-bolt....but here's the markings that were on the top of the right axle tube.
Only saying this in case yours also has stamped markings.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 06-21-2011 at 02:24 PM. |
Thread Tools | |
Display Modes | |
