Old 06-23-2011, 12:49 PM   #1
Silverray76
Silverray76's Avatar
stalled my truck now it wont fire
I need help i was driving to work this morning and got a block down from my home and my truck stalled. Now when i try to start it it wont fire all it does is cranks. I have a eldelbrock carb on it and a stock fuel pump. The same thing happened yesterday but i was able to get it started any thoughts Its a 76 c10 with 350
1976 c10 stepside 350/350 My baby
1991 suburban 1500 350/700 The hauler
Silverray76 is offline   Reply With Quote
Old 06-23-2011, 01:01 PM   #2
78maliburat
Re: stalled my truck now it wont fire
Spark + fuel ..it takes both to run
78maliburat is offline   Reply With Quote
Old 06-23-2011, 01:22 PM   #3
Goldfinger
Goldfinger's Avatar
sometime the butterfly closes and blocks air. try putting a screw driver down it to open it up and try to crank it. it should fire unless theres something else wrong
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 06-23-2011, 02:02 PM   #4
xrcr
2nd on the spark and fuel. If you have fuel and no spark is it an HEI. I've had the module crap out before. It won't run.
xrcr is offline   Reply With Quote
Old 06-23-2011, 05:31 PM   #5
TDS-MN
verify if you have fuel flow. Pump can fail out of the blue, had it happen to me with no prior symptoms.
good luck!
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
Thread Tools
Display Modes
