Old 06-23-2011, 06:30 PM   #1
moose666
Driving me nuts
okay hey everybody this is my first time posting and it may seem like a silly problem but i just cant figure it out. okay i baught a 78 gmc shortbox stepside that was already lowered and as i am to understand it has 2.5" drop spindles with a 1" drop coil. my problem is it cam with some funky 70's mags on it so i baught a set of stock rally rims had them painted and wrapped with rubber. the problem began when i went to put them on the truck. they went on ok but when i let the truck off the jack and when to move the truck it cleared the wheel weights off and was digging the end of the a arm into the rim. i see tons of lowered trucks like mine running stock rims and i just cant figure out why mine are giving me so much trouble. the rims by the way are stock 15" by 8" wide with 4.5" backspacing. so any help with this is most appreciated
moose666 is offline   Reply With Quote
Old 06-23-2011, 07:53 PM   #2
Re: Driving me nuts
I know on my 70 i had to shave/grind the edges of the lower a-arm so that 15" wheels would not rub. I believe that is pretty standard practice with *8" wide wheels. I believe the narrower wheels don't need that.
Old 06-23-2011, 07:58 PM   #3
1LowToy
Re: Driving me nuts
Well first of all we need to see pics!!!!!!!!!!!!!!!!!!!!!!
Well here the other bad news. You likely have 3" spindles and who knows how much spring. I did nearly the same to mine. I was with the 3" spindle and 3/4s of a coil cut off and it made the control arm come way too far down onto the wheel.
Corrections were a 3/16" wheel spacer and a stock spring. And still had to grind some off the lower control arm. Careful don't get carried away or it will collapse.
Oh and we need pictures!!!!!!
Wecome to the forum
1LowToy is offline   Reply With Quote
Old 06-23-2011, 08:32 PM   #4
rwhit57
rwhit57's Avatar
Re: Driving me nuts
Yes it's very common with 15" wheels, and yes again, you don't want to take off too much. Don't get into the radius of the arm. I had to take off quite a bit on this truck, but plenty of miles and no problem. I have never had to cut off this much, but it was to clear the old American 200s mags and they are 15"X7" . I take a die grinder and a cut-off wheel to remove whats necessary and then clean it up.
rwhit57 is offline   Reply With Quote
Old 06-23-2011, 10:29 PM   #5
moose666
Re: Driving me nuts
thanks guys i appreciate all the info and ill get pics up asap
Old 06-23-2011, 10:45 PM   #6
1LowToy
Re: Driving me nuts
My truck is a garage queen at the moment. I plan on beefing up the control arm to prevent collapse. It has happened but nobody is fessing up with pics.
Old 06-23-2011, 11:01 PM   #7
moose666
Re: Driving me nuts
i thought another way to get around it was also to move up to the tube style a arms
Thread Tools
Display Modes
