Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Hey Reumster,problem with LED inserts
My new LED inserts work but not properly.
Do I need a special electronic flasher.I'm already running a H/D electronic flasher. 1st the brake lights,4 way flashers,running lights and turn signals all work fine with the reg. bulbs in. With the lights off only the drivers side will blink.with the lights on no turn signals at all.brakes work,they light up nice and bright,but no turn signals. Anyone have an idea what's the problem. Again everything works properly with the regular bulbs in.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
Like a Rock!
I think you do need one.
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
Boosted Member
I'm having sort of a similar problem. Like BobbyK, everything works great with the 1157s in.
Running Lights alone - work Brake Lights alone - work Brake lights with taillights - work Turn signals alone - "work" but only flash dim, like the running lights, not with the intensity of the brake lights. Basically, the turn signals are only lighting up to the level of running lights when the headlights are on. I just replaced my flasher with an electronic one. Any ideas, Ryan?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
aka Crusher, Crushergmc
Check your ground. Make sure it's bare metal to the ground wire (no rust or paint). Typically LED's are more finicky about that.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
On my set I used just a cheap electric flasher. I had the same problems with my tail lights and it was all because they wern't clean. I'm not talking clean to the naked eye, I'm talking clean to a new white cloth. Really clean the sockets well and you shouldn't have any problems.
This is only my opinion and it is subject to change. 70 GMC Short box stepside Blown 388 Stroker 72 K/5 Blazer 350/SM465/205 |
![]() Join Date: Mar 2000
Just a thought but maybe that electronic flasher isn't seeing enough of a load. Those LED's don't draw alot do they?
Saskatoon, Saskatchewan Canada |
Like a Rock!
What type of flasher is the correct one to make everything work properly?
L.E.D. Freak
Wow sorry I missed this post. Yes you may need a electric flasher AutoZone its EL12, but just have to match the stock 552 prongs with a electric one. Let me know if it corrects the problem if not we'll send you a new set.
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
L.E.D. Freak
Also sometimes due to the 30 year old housings they are wore a bit , being careful not to ground out the two terminals at the bottom of the bulb base rap some tin foil around it. And like was mentioned allready clean. Electric parts cleaner, and Q-tip, and then some dielectric grease can't hurt.
Also the springs in old sockets can be weak, so with power off push in on them a few good times while spraying with cleaner. Let me know.
Thanks,I'll give those ideas a try.I'll post with the results.
Thread Tools | |
Display Modes | |
