Old 06-29-2011, 11:40 PM   #1
David67
David67's Avatar
Is this looking like a 4/6?
The bed has been set on there since and it appears that the back is lower. I know that more weight will be on the front but do yall think it'll bring it down to what an ECE 4/6 drop should be? I've always thought they were a bit lower.
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 06-29-2011, 11:42 PM   #2
David67
David67's Avatar
The bed has been set on there since and it appears that the back is lower and where it should be. I know that more weight will be on the front but do yall think it'll bring it down to what an ECE 4/6 drop should be? I've always thought they were a bit lower.
1967 C10
IG: david_r67
Old 06-29-2011, 11:43 PM   #3
David67
David67's Avatar
Re: Is this looking like a 4/6?
For some reason it posted a second time....check the one with the pics
1967 C10
IG: david_r67
Old 06-29-2011, 11:44 PM   #4
David67
David67's Avatar
gah ignore that.....my computer's weird
1967 C10
IG: david_r67
Old 06-29-2011, 11:50 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
front looks high but you've gotta lota parts missing still....
John
1999 Toyota Tacoma 4x4
Old 06-30-2011, 12:28 AM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
If the bed was on it, it would be lower in the rear already, and the engine is going to drop it down at least a couple inches, so its probably right. ECE is great stuff, so it should be as low as any other similiarly equipped truck with ECE stuff.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-30-2011, 01:05 AM   #7
David67
David67's Avatar
The bed's on it now and the rear sits where it's supposed to. The engine/trans are already in........... Yea I've heard a lot of great things about them and there's still a lot of parts to go on. Just thought it'd be lower by this point!
Yep we'll see
1967 C10
IG: david_r67
Old 06-30-2011, 08:27 AM   #8
68Stepbed
68Stepbed's Avatar
The great thing about ECE is if the front doesn't sit right when you get it all together, they may be willing to swap out springs as long as there's no miles on them. They offered to that on my old 4" drop springs, but I had already had them on the truck and driving around on them for about 8 months.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-30-2011, 10:40 AM   #9
19seventeeCustom
It looks about right, what size tires are in the front?
It maybe about a 1/2" too tall in the front, but like was already mentioned you still have some weight to add to the front of the truck, so it should be right on after that.
19seventeeCustom is offline   Reply With Quote
Old 06-30-2011, 10:50 AM   #10
50mercfan
50mercfan's Avatar
are the front springs alined up in the spring pockets. happed on my 57 chevy and i had to take one back out.
50mercfan is offline   Reply With Quote
Old 06-30-2011, 11:15 AM   #11
David67
David67's Avatar
Yea I'm just hoping they didn't send me a 2/6
I'm not sure if they would because I've painted them. Did yours settle in after that long? Also, when yours was at this stage, did it sit about like this? Thanks.
Yea I hope so. It's a 255/55/17 on the front. Thanks
Yep I'll check again but I made sure when it was going together.
1967 C10
IG: david_r67
Old 06-30-2011, 11:15 AM   #12
David67
David67's Avatar
Yea thats what I'm thinking...
1967 C10
IG: david_r67
Old 06-30-2011, 04:52 PM   #13
AusTx68
AusTx68's Avatar
When I first installed my ECE 4/6 kit it sat high too. Then I realized when I initially purchased the kit I was running a big block. I switched to a 383 after I built up the frame and never thought about the difference. I called ECE and switched from BBC to SBC front springs with a 2" drop for an overall 4.5/6 drop. I'm very happy with the results.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 06-30-2011, 05:01 PM   #14
David67
David67's Avatar
Whenever I was first got them it I was running a 292...and now have a 350. I know that's a heavier engine so maybe they sent BBC springs? And you got the 2" instead of 1.5?
1967 C10
IG: david_r67
Old 06-30-2011, 05:10 PM   #15
AusTx68
AusTx68's Avatar
Right! When I picked up the SBC springs I found out they offered a 2" drop spring and went with it. The extra .5 isn't much but looks good.
Old 06-30-2011, 05:15 PM   #16
David67
David67's Avatar
Sweet yea I just got off the phone with ECE. They said they would've sent the same springs as a SBC for the 292. I'm going to have to just wait till all the weight's on to see what it looks like and maybe swap over to the 2 inch! Thanks for the help.
1967 C10
IG: david_r67
Old 07-01-2011, 09:28 AM   #17
68Stepbed
68Stepbed's Avatar
No, because I already had my 1" springs in for a few years, then just added the drop spindles during the resto.
Matt
Old 07-01-2011, 09:17 PM   #18
72BlckButy
Tot Roddin'
72BlckButy's Avatar
For comparison, here's my '69 with a 4.5/6" drop w/ 250 I-6 and 2 spd powerglide (both original). I would set the engine and see how it looks at that point; no need to remove springs if you don't have too.
The following measurements were made before and after the 4.5/6" drop, with the ralleys and 235 75R15's. Additional information can be found in my build thread in my signature (click Blank Slate below).
Before the drop:
Driver's Side Front: 33 1/2"
Driver's Side Rear: 33"
Passenger Side Front: 33 1/4"
Passenger Side Rear: 32 7/8"
After the drop:
Driver's Side Front: 28"
Driver's Side Rear: 29"
Passenger Side Front: 28 1/4"
Passenger Side Rear: 28 3/4"
After the new wheels (4/3/10):
Driver's Side Front: 28 7/16""
Driver's Side Rear: 29 5/16"
Passenger Side Front: 28 1/2"
Passenger Side Rear: 29 5/16"
NOTE: It is always important to measure before and after the spring install to ensure you receive the correct springs from the supplier.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-01-2011, 09:38 PM   #19
David67
David67's Avatar
Wow thanks Nate! Well the pictures you see are with the engine already in. I should've measured before but even when I removed the front coils, I found out that they were both broken! I'm just going to wait until all of the weight's in and then see how it looks and see if I need to go anywhere from there. I might also have to address an issue with my front wheels. At the time I didn't realize that the spindles would push the front wheels out so the front track width is 3 inches wider overall than the rear. Nothing pokes outside of the fenders but the front is kinda close.
Thanks!
1967 C10
IG: david_r67
Old 07-01-2011, 09:39 PM   #20
David67
David67's Avatar
That's one of my favorite trucks on the board!
1967 C10
IG: david_r67
Old 07-02-2011, 01:25 PM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks David!
Just wanted to say that the note I mentioned above about measuring was for anyone that is reading this thread and planning on lowering their truck.
Just out my build thread for what we did (15x7 ralleys) to accomodate the 3" spread on the front wheels. The truck is looking great, keep at it.
-Nate
Old 07-02-2011, 04:00 PM   #22
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks pretty good to me and im sure it will settle with some drive time and a more complete truck..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-04-2011, 09:52 PM   #23
David67
David67's Avatar
Thanks I sure hope so!
Originally Posted by 72BlckButy View Post
Thanks David!
Just check out my build thread for what we did (15x7 ralleys) to accomodate the 3" spread on the front wheels. The truck is looking great, keep at it.
Just checked it out. So you had to go with different wheels to "fix" it? I'd hate to sell the ones that are on there but I think I'll have to and get some with different b.s. And I also saw that you trimmed down the lower A-arm. Is this necessary?
1967 C10
IG: david_r67
Old 07-05-2011, 02:53 PM   #24
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Not necessary, just eliminated any rubbing on the ralleys when they were on there. I didn't have to upgrade to the 20's but that was the initial intent anyway. The 15x7's just helped suck the front wheels back in with the 8's on the back.
-Nate
Thread Tools
Display Modes
