Old 07-02-2011, 06:15 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
What to inspect/look for 2004 LQ4 145k miles
It is getting close for me to come home and start working on my truck. The 2004 LQ4 that I bought was a running engine with 145k on it. I am trying to avoid a rebuild bc I will be doing a stroker kit in the near future. I want to run it stock until I get all my parts together bc the 305 in it now is toast.
Compression Check and Leak down test. Can I turn it over by hand or bump the starter on an engine stand to get the appropriate readings?
Oil, clean not "burnt", no metal or water.
Plugs I will just have to find a guide to "read" them
Bores I will have the heads off to inspect bores
Bearings Can I pull off a rod cap and look at the bearings w/o replacing? Same with Mains.
What else should I inspect/check?
Just trying to get my game plan in order
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 07-02-2011, 11:35 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: What to inspect/look for 2004 LQ4 145k miles
I wouldnt pull anything apart unless I found something real bad in the oil. check that first, if it is clean and free of metal, cheange the oil and filter, throw it in the truck and continue the build. These LS motors will run fine for over 200K with normal maintenance and not beating them to death. this way it will allow you to keep money in your pocket and finish the swap quicker so you can enjoy and save strocker parts faster.
just my opinion....
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-02-2011, 12:22 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You should be able to do a comp check just by bumping over with the starter.
I wouldn't bother checking the bearings or pulling the pan, since you didn't find any shavings in the pan, the bearings should be fine. Even with a good filter, if you lost bearings, you'd find a sign in the pan.
I'd flush out the water jacket if its been sitting empty, just to get any scale out that might have built up. After its running, Id get some seafoam through there to get the inevitable carbon buildup out. I took my intake mani off and cleaned it as well, since its really the only time you have the chance.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-02-2011, 12:33 PM   #4
softballnrd27
I haven't done any thing with the motor yet. It is still sitting on the tire in the garage.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Thread Tools
Display Modes
